- Thank you received: 20
more power?
- nads.com
- PLUMMEN
- Thank you received: 104
- StreetfighterKz
- Thank you received: 117
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- Old Man Rock
- Thank you received: 225
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Mark Wing
Why ask......your magic:woohoo:
Yorba Linda Cal.
- nads.com
- Thank you received: 2098
... accidents happen... magic... Fire flys from my finger tips when my eyes open wide, and all creatures big and small RUN for cover... speed is up, adrenaline is through the roof captain. ON DANCER, ON COMET, ON KZ! TO the TOP OF THE WORLD! And BEYOND!
After joining the creatures, nads soon decides to work a little slower, keeping only one eye open. :lol:
- keith1
- StreetfighterKz
yes no gasket, stock valves, it has doesnt matter cams in it.
I've never heard of a Kz engine using only o-ringed cylinders to seal it. The o-rings are always used in conjunction with a copper head gasket. You're going to have a lot of oil everywhere without some sort of head gasket.
The cams will matter eventually as it seems like you have a lot of flow for a 1015 engine.
Later, Doug
1989 Vmax
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- Old Man Rock
As others stated, you're going to need some sort of gasket one way or another or oil all over the damn place.
With a 1015cc, assuming this is a kz1000...
For more power (I think that's the question) you can go with the following...
Big block & cylinder kit from APE, MTC. To what power degree up to you, skies the limit, expect big $$$!
Have sleeves installed and go higher in your piston kit selection.
Or bore the cylinders add a 1075cc piston kit, no sleeves required.
Upgrade your cams, .410 or higher...
Upgrade your carb's, 34's or higher...
Hell, you can even turbo/super charge it for the right $$$...
In staying with a 1015cc motor with no change in cams or carbs there's only so much you can expect in power increase...
OMR
BTW...
And even if you say it won't work i'll MAKE it work, just because I can. Cuz i'm magic see. Just plain magic.
Who's smoking the whacky tabaky, you or Yoda! :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
Run a real high compression (20-1 or so) and just weld the head on. That should do it. Stock cams will be fine and all those morons who weld your cranks are suckers for paying for that. You might want to move up to a set of 28mm carbs just so you have enough juice for the top end. Make sure to take lots of pics!
there ya go...problem solved!!!!:laugh:
