- Thank you received: 3
KZ650 hop up parts vendor?
- Dave Sloan
What carbs are you going to use?
Z650B2 - Injected
- Skinthead
I am planning to megasquirt the setup, so EFI will be the way I go with this. I am going to use some GSXR 750 Tb's on it. Planning to port the head anyway, so a std KZ head will be fine.
Also picking up a 550 bottom end off ebay for the tranny. I want the 6-speed tranny. All else can be worked out from there.
Skint
81 CSR 1000, 81 KZ650, 83 GPz550
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Skinthead
Modding hte spacing is fairly easy, and reworking the fuel rail just requires a new section of rail from a vendor I have a listing for. Casting up the bases for them will take a little thought as I have to cast them with a bit of an internal taper to match the heads.
I shoudl be getting hte biek home some time this week, and will be posting lots of pics. Be watching the projects thread titled "Peeled Onion projects" for pics and details of what is happening next.
For those that hate my typos, I hope to be getting htat rectified this week. I have my right hand cut for carpal tunnel friday morning.....lol.
I think I have just about everything figured out on this monster. I am holing off on the tranny purchase for the moment. They pop up so I am not too terribly worried about the conversion to 6-speed right away. I have enough going on in the rest of hte engine to keep me busy....and broke....for some time.
Skint
- 77_650B1
Yeah reworking the spacing shouldn't be too bad, I was sizing up doing something similar as well, but then I decided just to get a set of BS34's. My bs's are from a 95 police, very clean. I'll be following you closely, I'm doing something similar, but I'm going to be away until the end of april, so my project thread wont be online until May.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Skinthead
lots of info on the net on home foundry work. READ alot before you try this stuff at home. A screwup can be painfully disastrous or deadly.
I will take some time with a friends mill to work up the casting models in wood for the adapters, and cast them all at once. Just a little finish work to get them usable from there.
I save junk engine parts, pistons, junk lawn mowers, and any unsellable part of aluminum I take off other bikes I have and stash them away. Currently something like 200+lbs of aluminum waiting to be melted down for ingots. once I have some good clean stock to work with I will be casting several pieces i need for the bike. Planning to work up the rear sets in wood and casting them too.
If you want to get into casting stuff on the cheap take a look at www.lindsaybks.com and order a catalog of books. I bought the gingery machine shop series from them some time ago, and that is where I got started. There is nothign to it.....
Skint
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Skinthead
The furnace is only as complicated as you wish to make it. You can get the furnace clay from Grainger, but you will have to know someone who has an account there. mcMaster Carr may carry it as well, but I have never looked there to see.
I will look on the 2 bags of stuff I have and see fi I can find a website for them and send you a link.
One other thing I have to think about is pressing the crank apart, and where to get new pns and bearings for it. I might send it out, but I'd prefer to do it myself.
Skint
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- steell
Our cranks come apart? I thought they were one piece cranks on our bikes?
They are, it's going to be real tough to get one apart without destroying it
Anyone can buy at Grainger, just name any company local to you and tell them you're paying cash
- 77_650B1
Where have you been steve? I was thinking your expertise could be used in a couple of these threads haha.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Skinthead
Are Carillo rods available for these engines? I'd like to bulletproof the bottom end on this thing as much as possible.
Skint
