- Thank you received: 2
Oil Cooler
- keith1
- keith1
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
I have mine sitting in the freezer of my refrigerator here at work, and it's currently reading 9.8 Degrees F and slowly going lower. That doesn't seem right, but it's sitting in the frosted metal freezer section.
5.3 Degrees F now as I finish this post, abnd it looks to have stopped going lower.
'85 GPz550(ZX550-A2)
- keith1
Thanks for the pictures. That goes into an oil galley, right? Unfortunately on my engines, there isn't any place to install one of those where it's visible. While you have it out, boil some water and see if it reads 212 Degrees F.
actaully the one in the galley is a pressure guage, the temp guage screws in place of factory oil fill cap.....like i said, i dont know how accurate it is, one of these days i ll try the
boil water trick.....used to do that years ago to test car thermostats.......
- CoreyClough
- GPz550 Addiction
I wonder why the numbers from 180 to 260 are bigger than the rest? Maybe they're trying to tell us something?
The Autometer read a little over 212 Degrees F when the water started to boil. Not bad.
So there I have it. the temps I was reading were correct on the Daytona. It's going back on tomorrow, and this weekend better oil will be used in all of my oil-cooled engines from now on.
Thanks for the space for learning.
- CoreyClough
- GPz550 Addiction
