Oil Cooler
- chelms27
Oil Cooler
04 Dec 2008 14:15
I am un sure of where to post this so I picked here. I have an oil cooler on my 77 KZ1000 and I though it was stock? I have been told that it is not.?
1977 KZ1000...16k miles 2nd owner all original except tires, dyna-coil, and a vance and hines 4 to 1 exhaust.
- keith1
Re: Oil Cooler
04 Dec 2008 15:18
chelms27 wrote:
as far as i know, they did not come stock with oil coolers.....then again, what the hell do i know?:laugh:
- mtkawboy
Re: Oil Cooler
04 Dec 2008 15:29
First one stock with a cooler was a GPZ1100 I believe
- RonKZ650
Re: Oil Cooler
04 Dec 2008 16:05
Yea 1981 was the first cooler from the factory on the GPZ550 and GPZ1100. KZ1000 Eddie Lawson Replica was the only KZ1000 from the factory with a cooler. Even the police bikes in later years didn't have an oil cooler.
- chelms27
Re: Oil Cooler
04 Dec 2008 16:46 - 04 Dec 2008 16:48
Thanks for the replies, My next question is does anyone have an opinion on whether I should keep it on the bike or not? I am looking at keeping the bike mostly stock..but if the oil cooler is a big benifit I will leave it on. Otherwise sell it? Oh I am aware that unsure is one word..oops
Last edit: 04 Dec 2008 16:48 by chelms27.
- keith1
Re: Oil Cooler
04 Dec 2008 16:58
chelms27 wrote:
DEFINITELY keep it....huge benefits from an oil cooler..there is a reason most of them have one...
i wouldnt be without one with an air cooled motor..
these things need all the help they can get in the cooling dept, especially in the summertime....excess heat kills!!...keith
- cnyl
Re: Oil Cooler
05 Dec 2008 05:04
I'd like to get an oil cooler but I have a question.
Do you run the same amount of oil as you would stock or do you need to use more? Do you still go by the site glass?
Thanks;)
Thanks;)
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- Mcdroid
- Gone Kwackers
Re: Oil Cooler
05 Dec 2008 06:15
cnyl wrote:
Yes, same amount of oil:)
Thanks;)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- rstnick
Re: Oil Cooler
05 Dec 2008 06:31
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- mtkawboy
Re: Oil Cooler
05 Dec 2008 09:16
I dont think you really need them on a bone stock regular 1000 or 900. My 1105/900 block definetly needs one, you can feel the heat coming off of it especially in traffic. Going across the Mojave desert I was glad my 82 GPZ 750 had one on it at 117 degrees. A thermostat on them is what you need so the oil isnt too cool.
- cnyl
Re: Oil Cooler
05 Dec 2008 14:24 - 05 Dec 2008 14:25
Thanks guys. Not meaning to hijack your thread chelms27 but what brand would you guys recommend and where do you get them? I assume they come in different sizes so what would I need for my stock motor? Someday when my money tree starts growing again, I plan on a big bore job so will the same size work or would I have to upgrade?
Thanks;)
Thanks;)
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
Last edit: 05 Dec 2008 14:25 by cnyl.
- MFolks
Re: Oil Cooler
05 Dec 2008 14:47
A website called "Earls Service Shop" has oil coolers,fittings and hoses that might work for you.
www.earlsserviceshop.com/
