- Thank you received: 104
thoughts on this 1075
- PLUMMEN
- CoMIYC
Sorry I was half asleep when I read the post.
modprod wrote:
CoMIYC wrote:
The 1075 is a good engine still using the 903 sleeve size even though it's Wiseco. The next bore size starts around 1100 just FYI if you ever intend putting your bike on the track.
Sorry 1075will "not" work in 903 sleeves but will in a stock 1000 block 1015 is the most you can go in a stock 900 block
www.birdsperformancecoatings.com
75 Z1B 1135, 83 GPz 1170, 85 RZ350, 86 RZ 350, 2000 ZX9R
Gone: 81 CB400T, 83 Kz750
AKA: Don
- racer54
- Thank you received: 114
Biggest bore in 903 cylinder is 1015 and you can go to 1105 in 1015 cylinders although at 1105, the cylinder walls can get a little thin. Most stay with the 1075. Not much difference between 1075 and 1105 but the 1075 helps keep cylinder in check.
- roy-b-boy-b
- Thank you received: 103
- saxjonz
- KawboyZ
- Thank you received: 76
79 LTD B3
- roy-b-boy-b
I borrowed the money from my bank to rebuild the engine and they wanted to know how much the bike was worth and i told him if he loaned me $2500.00 i guess it would be worth $2500.00. He gave me the money. Roy
- larrycavan
- Visitor
They are one of the worst grinds to setup for oversize valves because they have a 1.110 base circle combined with a lot of overlap lift.
Andrews should have made them with a smaller base circle IMO.
- roy-b-boy-b
I'll check out the cams and the head real good.
I have a friend in Harrisburg,Pa. that usally has a lot of the old goodies. The same guy i bought my Tracy off of.
Roy
- saxjonz
- KawboyZ
Lol. Gotta love it. Them bankers are something. They lent an old lady here at the hollographic museum a million dollars for which she kindly gave most of it to two associates that promised her a new type of hollographic tv and the loan officer is the same guy who financially supported Obama. Needless to say they gave her that loan fully knowing that she would never be able to pay it back no matter how hard she tried. The point? Well, I guess her building happened to come up in to the boom that all these wonderful nice people on the North Side spent 5 times a buildings worth to own so they could live in that "circle" of people who overspent. Happy contractors became very affluent I am sure. At any rate her building on the corner was at the time worth 3 Million dollars and you know what? It was paid for I believe.I have the Mark II engine. I think my compression is 12/1. I could be wrong. But the domes are way up there. I can't run low grade gas.
79 LTD B3
- saxjonz
- KawboyZ
Ahhhhh. Well there it is. The real reason why everyone loved those cams. That whole freight train effect. lol That will put a smile on everyone's face including the not so easily scared by acceleration type. Most guys probably only thought of the whole acceleration curve and not so much about destroying their engines. So much that I have to learn about stuff.3X cams have a lot of overlap. They can be valve benders if the valves are not sunk or you miss a shift without a rev limiter. They pull like a freight train from 5K up.
79 LTD B3
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
