- Thank you received: 2098
Repair Diagnosis/Top-End Rebuild?
...never checked valve clearance in the 6xxx miles I've put on the bike....
Screw MaKaw and the manual she rode in on! :woohoo: :laugh:
- steell
One question on these carbs..Is it normal to have a sound like birds "twittering" in synchrony lightly emanating from newly synced carbs? This new noise has coincided with getting them synced-the noise wasn't there before..I think it may be the sound each carb makes as it gulps air? Doesn't sound terrible but it does sound like light repetitive twittering (and can only be heard at idle) The noise goes away as soon as I give it a little gas.
At least one, and probably more, of the carb holders (manifolds) has a vacuum leak.
- MFolks
- Thank you received: 540
- keith1
you might want to square this away quick as an air leak in that area can result in piston meltage due to a lean condition..
