Repair Diagnosis/Top-End Rebuild?
- onanysunday
I'm still not sure what happened here. I know there had been small pebbles caught in the sparkplug wells on a few of the cylinders-could've fallen into the combustion chamber when I changed plugs. Any ideas what is wrong w/cyl.2?
Also, does anyone know if the wiseco pistons have higher compression ratios than stock pistons, causing more wear and future re-builds more often? How does that change the feel of the ride for the mighty KZ? Thanks.
79 KZ1000 E-1
VM28SS
K&N Pods
- keith1
- Thank you received: 2
that.....good luck
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- bountyhunter
- Thank you received: 337
The bike has been running rough and louder than usual. It seemed to happen overnight. I'd recently changed fouled plugs, the next thing I knew the bike was running terrible. It ran like it still had fouled plugs-bogged down, unable to make clean rhythm. Deciding a good place to start was to actually "read" the plugs, I found 3 plugs with an acceptable light grey color but cylinder 2 had wet, gas residue?! My guess would be a worn intake valve causing a poor valve seal. Any ideas? I am guessing I will need a top-end rebuild and am looking at purchasing a Wiseco overbore kit and a valve job at the same time. Has anyone had this work done before? What is an estimated cost for parts/labor? Is it common to need a top-end rebuild on the KZ1000s after only 18XXX miles?
Yes. The machine shop that did my head way back when was contracted to do the maintenance on the local PD bikes which were KZ1000's. He told me they needed a valave job about every 20k miles with city riding.
Bikes eat up top ends way faster than cars. Bikes are air cooled so the valves and seals run way hotter and don't live as long.
Check compression, then check valve clearance. If you have low comp on only one hole, it's likely a valve.
- timebomb33
- steell
How do you go from fouled plug to bad intake valve seal in one jump?? Most people would blame the carb
Could be carb, could be ignition, you need to do some checks to determine that.
Any ideas? I am guessing I will need a top-end rebuild and am looking at purchasing a Wiseco overbore kit and a valve job at the same time. Has anyone had this work done before? What is an estimated cost for parts/labor? Is it common to need a top-end rebuild on the KZ1000s after only 18XXX miles? My '86 Nissan 300ZX Turbo has 189XXX miles with an original top-end. I guess you never know.
Does your Nissan 300ZX turn 9000 rpm?
Is your Nissan 300ZX air cooled?
Can't make a meaningful comparison between apples and oranges.
Are you running this bike without air filter(s)??
If you have pebbles stuck in the spark plug cavity, I'd really hate to see what your pistons and combustion chambers look like.
Wiseco has at least 10.25:1 (maybe 10.5:1) and 12.5:1 piston kits available.
I don't see how increased compression alone is going to cause more wear and tear, but detonation due to lack of octane required by higher compression certainly will shorten the life of a motor.
The posts above this one offer some good advice.
- onanysunday
For years motorcycle enthusiasts have sung the praise of air-cooled engines and convinced me of their merit(simplicity), but if in fact, they contribute to premature top-end rebuilds because of their higher operating temperatures I have to make sure to go with a liquid-cooled machine next time. I never realized air-cooled was that much worse than liquid as far as longevity. Understandably, motorcycle engines will have a hard time lasting as long as a car engine because they rev higher (as a general rule) and are smaller, but there should be a reasonable compromise between one top-end lasting 18xxx and the other 186xxx. It appears this is simply the limitation of the older technology vs. the new. In any event, testing will show the cause to this problem.
I know that race machines are almost always running higher compression and many require a tear-down and rebuild after every race. I like the increased power and performance of higher compression engines and these 12.5-1 Wiseco pistons, but not if it has to come at the expense of reliability/burning through rings prematurely. Maybe original is best?! Thanks guys.
79 KZ1000 E-1
VM28SS
K&N Pods
- timebomb33
- onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
- bountyhunter
they are not fragile and they do last guite well
My KZ750 twin went about 58k on the original top end before needing work, and that is mostly city miles which are worse than highway on the engine. The guy at the machine shop figured at 58k I was coming in for the SECOND valve job, couldn't believe it was the first.
That said, his top end rebuild went about 17k before the valve seals failed and the oil started fouling the valve seats and spark plugs. he may have used bad parts, I didn't see them. That could be why he figures top ends only go 20k?
Anyway, I would check the valve clearance and re torque the head and check compression cold and hot before pulling the head. You may not need a valve job, but you might. Compression should tell you.
- timebomb33
- onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
