- Thank you received: 109
Repair Diagnosis/Top-End Rebuild?
- mark1122
- Keep twisting it
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- APE Jay
- Banned
- Thank you received: 58
Jay
- kpier998
Deciding a good place to start was to actually "read" the plugs, I found 3 plugs with an acceptable light grey color but cylinder 2 had wet, gas residue?! My guess would be a worn intake valve causing a poor valve seal.
I wouldn't do anything until I checked carb float levels and other normal items associated with "gassy" smelling plugs - including switching to a new plug and possibly a new plug wire / cap. To minimize cost, you could swap the plug and wire to another cylinder to see if the problem follows the plug/wire combo. If so, then it might just be a bad plug or wire. If the problem is still with the same cylinder, check the carb next.
These things don't take a lot of money to check. If you don't find the problem, then spend the money on compression check/leakdown test etc.
My 82 ltd 1000 went over 50k miles before burning an exhaust valve on cylinder number 3 and needing the head reworked. I think I was having some other problems that led to this - namely that there were "dirt dobber" nests in the holes through the cylinder fins that I couldn't see which led to continual overheating. Dirt dobbers (if you don't have them) are wasp-like creatures that poke mud into any hole they can find and lay their eggs (and some spiders for the offspring to eat) in the hole. Then poke some more mud in the hole. Not good for an air cooled engine...
- onanysunday
However, part of the problem is that it is also burning more oil recently but plugs are not fouled in any way. This only started a few months ago. I am not sure that can be a carb problem..what do you think?
So, after the carbs are cleaned, then it looks like a leakdown test and/or a compression test if it's needed. I do have a question..how do you check resistance of spark plug caps while keeping the caps connected to spark plug wire? I had to pull back insulation around the cap to find a metal contact point and by the time I had done that, the cap fell off the wire and it didn't seem electrical testing was possible. Am I missing something? Ideas on how to do this in the future? I have the shop manual but it didn't give any specifics on HOW to do this-it only showed the contact points and gave specs..Also, I cut the spark plug wire back 1/4" and re-attached spark plug wire by screwing its rubber wire back into the cap, problem is it doesn't seem like a secure fit and the new connection feels a bit looser than all the others. It seems like a weak design for an electrical connection because all you have to do is pull with slight pressure to remove the cap from the wire..
79 KZ1000 E-1
VM28SS
K&N Pods
- Thank you received: 2829
- MFolks
- Thank you received: 540
- PLUMMEN
- Thank you received: 104
- steell
- onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
- gane
[img][/img] 1977 KZ1000A1
- Thank you received: 2098
... check valve clearance. If you have low comp on only one hole, it's likely a valve.
Ma Kaw's routine maintenance schedule for 1979 KZ1000 specifies checking valve clearances every 5000 kilometers (or 3,000 miles).
Good Luck!
- onanysunday
One question on these carbs..Is it normal to have a sound like birds "twittering" in synchrony lightly emanating from newly synced carbs? This new noise has coincided with getting them synced-the noise wasn't there before..I think it may be the sound each carb makes as it gulps air? Doesn't sound terrible but it does sound like light repetitive twittering (and can only be heard at idle) The noise goes away as soon as I give it a little gas.
Although I've never checked valve clearance in the 6xxx miles I've put on the bike, it is running incredibly smoothly right now (and of course new plugs never hurt either) I don't notice as much smoke any more so I am going to leave it at that and not try to mess around w/ anything any more. My experience has shown that sometimes the best thing can be to leave it alone, because the more I tinker, the likelihood something can go wrong can be increased. However for the future I may consider a leakdown test or checking valve clearance. Thanks all!
79 KZ1000 E-1
VM28SS
K&N Pods
