- Thank you received: 10
KZ650 Performance Question - Where's my power?
- timebomb33
I THINK MY POWERBAND BROKE
- HerrDeacon
Thanks timebomb, just wanted to make sure. I guess I know where your line in your signature comes from now
- Thank you received: 2098
... have all the maintenace type things taken care of (i.e. carbs sync'd, coil mod, timing, etc)....
If not already done, would use strobe type timing light to verify operation of the automatic timing advancer unit by watching it move back and forth as the rpm are varied.
Would also spray water mist on header pipes while engine is running to assure combustion in all four cylinders. Spray should sizzle and immediately vaporize. It is surprising how well these bikes can run on just three cylinders. :laugh:
Good Luck!
- HerrDeacon
I also, checked the pipes and all four appear to be running. I do however have an issue with one cylinder not running when cold starting on the choke (I have another thread on that issue), but all four are working fine off the choke.
- OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- timebomb33
- HerrDeacon
deacon with a bike that looks as hot-rod as yours i figured you would have to be one of the last one's we would have to talk into twisting the throttle hard.
LOL, I know I find it weird too. I don't have an issue in the car. I just hope I can get out on it before I put it away for winter.
Thanks again guys for enlightening me.
- rstnick
- Thank you received: 377
I attribute it to not cleaning the points in the two years before. I didn't even adjust them as my bike seemed to run fine, until I rode another kz650 and felt a difference.
As suggested, switch gears at a higher RPM. When riding at a spiritted pace, I shift anywhere from 7000~8500.
I also find when I wear ear plugs my bike goes faster!
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- 77_650B1
I agree with the guys, get a Dyna-S and do the coil mod. Bike fires so effectively after that, you'll be amazed.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- HerrDeacon
I'll be putting mine away very soon too. I've heard great things about Dyna and will getting one this winter.
- KOOL RYDER
- KZ 650B2 / KZ 1000E
Wind it till it screams, and then give it a little more.
The pick - up is a riot. When I first tried to wind it out I was amazed how the power curve increases after 5500 RPM.
Make sure you have a nice firm grip when you do.....
That CB wont know what flew by down home on the ROCK.
K-ZEDS rocking the rock.
Give us an update after you wind her to the max.
KRB)
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- HerrDeacon
I'll be picking up a Dyna this winter. So, unless I can figure out what I did, I'll have to wait until spring to wind it out
