- Thank you received: 225
need cheap gaskets!!
- Old Man Rock
I mean as Patton provided, $8.95 plus shipping. So under $15 you get a gasket designed for your bike, seems like a hell of a bargain to me considering a hamburger, fries and a coke cost $7-8 any longer.
Yeah when we were kids we had 75 cents so fill up the gas tank or get good old dad to buy a gasket and work our asses off doing chores, hmmm... what to do, cereal box it is. Guess what, we're not kids any longer and even at $20, that truly isn't a lot of money these days.
I'm truly not trying to insult here, your bike and I should just keep my opinion to myself but I just don't get it, not for under $20 anyways.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
I've got a set here.What's the problem with them?
1980 KZ500 B2
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
Thanks againB)
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
- Thank you received: 2098
... valve clearance is 4k but cam chain tension is 2k
The valve cover is of course removed to check and/or adjust clearances. However, the valve cover is not removed incident to adjusting the cam chain tensioner.
I have the Z1E valve cover gaskets on my bikes and am well pleased with them.
Good Luck!
- bountyhunter
- Thank you received: 337
Bountyhunter...That reminds me... don't buy Athena gaskets......
I bought an Athena rebuild gasket set for my 750 twin. The valve cover gasket was crap, and the cylinder base gasket broke up and fell apart after I installed it and ran the engine for about 50 miles. When the cylinder base gasket fell apart I had to tear the engine down to the rods again and do the rebuild over. I was NOT happy.....
- SPARKY47
- 1980 KZ500 B2
I used to make gaskets from corn flake boxes for an S1 triple a couple of centuries ago.
They worked well enough for me to leave marks[still there as well:woohoo: ] on a local church wall at 85mph!
Ah the good old days eh?:blink:
1980 KZ500 B2
- bountyhunter
The one I bought was about $80.Bountyhunter,thanks for that.I wouldn't mind but this Athena set wasn't cheap,a case of try it and see I guess.
The gaskets that were bad were the thin material ones like the oil pan gasket, base gasket, all the same thin material. When it got hot, the gaskets hardened and cracked. They looked OK to my eye, but they hardened and got brittle.
YMMV
Pep Boys sells gasket material that is 1/16" rubberized paper a,d I think the number stamped on the gasket paper is N8904 or something like that. It works really well for base gasket, cover gasket, oil pan, etc.
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
