need cheap gaskets!!
  • thadley55
  • Topic Author
  • TWO WEEKS!!!(Money Pit the movie)
10 Oct 2008 15:23 #241151 by thadley55
need cheap gaskets!! was created by thadley55
Hey Guys,
Guess what? my KZ passed state inspection!!Yeah:silly: All I need now is registration and I'm GTG! Anyway before I start commuting I still need to address a few things like a major post-ride leak from the front side #1 cam plug, and also I would like to check and adjust valve clearance and cam chain tension. I need gaskets and plugs, is there any where I can get them without paying out the wazoo? I checked with Babbitt"s but they are pretty steep, any suggestions? One more thing, is there anything else I shoul do while I have it down?
ThanksB)
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
10 Oct 2008 15:42 - 10 Oct 2008 15:44 #241156 by Patton
Replied by Patton on topic need cheap gaskets!!
These from Z1E should do nicely ---
gasket
end plugs
Good Luck! :)
Last edit: 10 Oct 2008 15:44 by Patton.
10 Oct 2008 16:43 #241161 by bountyhunter
Replied by bountyhunter on topic need cheap gaskets!!
I have made cover gaskets from the best gasket material they sell at Pep Boys. Works very well, I wasn't up for paying the upside of $20 for valve cover gaskets.
10 Oct 2008 18:54 #241178 by ronjones
Replied by ronjones on topic need cheap gaskets!!
Gota agree for gaskets. Take your part put it on a scanner, large parts may take two scans. Make a template, trace on gasket material, cut it out and ya got a gasket for a couple of $.
10 Oct 2008 19:46 - 10 Oct 2008 21:26 #241185 by Patton
Cutting a perfect duplicate of this gasket from scratch seems like a rather daunting task (at least to me), even if further minimizing expenses by using a large cereal box or other free substance as gasket material. :)
Last edit: 10 Oct 2008 21:26 by Patton.
10 Oct 2008 19:50 - 10 Oct 2008 19:55 #241187 by SPARKY47
Replied by SPARKY47 on topic need cheap gaskets!!
tsk tsk!
1980 KZ500 B2
Last edit: 10 Oct 2008 19:55 by SPARKY47.
10 Oct 2008 21:27 #241197 by stardon
Replied by stardon on topic need cheap gaskets!!
When I was a kid and had to go through the Briggs engine on my go-kart I used the big side of a potato chip box and cut a gasket from it for the side cover. It worked pretty good. That's how to get a cheap gasket!
  • thadley55
  • Topic Author
10 Oct 2008 21:43 #241201 by thadley55
Replied by thadley55 on topic need cheap gaskets!!
Thanks for the suggestion for z1. I had forgotten about that site. I also want to thank those of you who offered the suggestion of making my own. While I appreciate the money I would save, I don't have the time or the patience to to take that on right now. Since my service interval is 2k I will consider making some from the outline of the new gasket I just ordered.
Thanks again!B)
10 Oct 2008 22:09 #241206 by bountyhunter
I buy one and use it for a template. I keep that one for making new ones.
10 Oct 2008 22:10 #241207 by bountyhunter
That reminds me... don't buy Athena gaskets......
10 Oct 2008 22:12 #241208 by Patton
If the old gasket is carefully and completely cleaned off the mating surfaces, the new gasket may be applied without any sealer, and the new gasket will usually survive several future valve cover removals and replacements.
A small dab of silicone sealer may be applied to the rubber end caps to prevent leakage through those areas. Be careful not to apply so much sealer that an excess squeezes out underneath the valve cover during reassembly. This is to avoid getting silicone where it's not supposed to be, such as inside an oil passage.
This would also be a convenient opportunity to check the valve clearances.
Good Luck! :)
10 Oct 2008 22:19 #241210 by Patton
thadley55 wrote:
... service interval is 2k....
Just to confirm, the FSM maintenance schedule specifies 4,000 miles or 6,000 km for checking valve clearances.
Good Luck! :)
