Base gasket
  • Bdog
  • Topic Author
  • Sweep the leg johnny!!!
04 Oct 2008 05:42 #240083 by Bdog
Base gasket was created by Bdog
Putting 810 kit in motor. Have the barrels bored and pistons, need a base gasket. will a stock base be ok? Is there a "high performance" gasket available?
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
04 Oct 2008 06:56 #240090 by Old Man Rock
Replied by Old Man Rock on topic Base gasket
I don't know about this for a KZ650 but for the KZ900, it was highly recommended that the cylinder studs also be upgraded.
Due to the higher compression ratio (10.25:1 vs. 8.5:1) on the new 1015cc piston kit I installed, I could probably count on blowing gaskets...
I also upgraded my CAM's so all in all, gasket upgrades were required.
I don't know the differences in your setup nor do I know if heavy duty studs are even available for the KZ650 but you may want to verify just the same.
Just a thought!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Bdog
  • Topic Author
04 Oct 2008 07:17 #240092 by Bdog
Replied by Bdog on topic Base gasket
I think the studs are useable for the 650s too. My jump in compression will only be around .75-1.25 over stock and I will be using Gpz cams. I have found all sorts of gaskets for the liter bikes, but not as much for the lightweights.
You bike is absolutely sick, by the way, has it been finished yet? I checked out your build thread a little bit ago, nice work!
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
04 Oct 2008 07:36 #240094 by Old Man Rock
Unfortunately no....:(
I still have a ways to go yet... Waiting for the funds for the head work @ Cavanaugh's (3 way grind w/mild port & polish) for the upgrade to .365 CAM's and manifolds for the Keihin 29mm CR special carbs.
Once I get this accomplished then she'll be ready to fire up at least.
I still need to upgrade to the Dyna ignition/coils and I want to install a Barnett clutch with new heavy duty springs as well. I already have a brand spanking new 4:1 Kerker with 1.5" competition baffle.... Almost forgot, new tires are needed...
Getting there but a ways to go yet... Probably around the first of the year she should be about completed... Until then, just getting all the other minor stuff done.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Bdog
  • Topic Author
04 Oct 2008 12:28 #240130 by Bdog
I actually just acquired a lightly used set of 3 ohm dyna coils and a brand new in the bag set of their wires when I got the 810 motor. It also came with an ignition plate but I don't think that it fits liter bikes. Fifty bucks and shipping if you'd like them. I just don't need 'em, I run accel coils and wires.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
04 Oct 2008 18:58 #240175 by PLUMMEN
Replied by PLUMMEN on topic Base gasket
ive run plenty of motors with more than 10.25:1 compression with stock cylinder studs and nuts,if youve got money to spend its fine but there are plenty of other things these motors need more.;)
  • Bdog
  • Topic Author
05 Oct 2008 05:08 #240212 by Bdog
go on...
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
05 Oct 2008 07:11 #240224 by Old Man Rock
Bdog... I pm'd you regarding the ignition/coils...
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
05 Oct 2008 07:39 #240230 by kzr750r1
Replied by kzr750r1 on topic Base gasket
Since you bring it up. In discussing increasing compression with Derek at Moto Lab. One of the items to remove is the base gasket from the assembly.
I may have misunderstood but what would the harm be if the cylinder was mated directly to the upper case with case seal?
Any opinions? Personally, I'd prefer at minimum to use a copper or bronze base gasket to have at least something sandwiched between these mated surfaces...
If such a beast is available for the 750 block.
Sorry to hijack your thread but it's sort of on topic...
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
05 Oct 2008 08:35 #240236 by PLUMMEN
Bdog wrote:
go on...
where should i begin?:laugh:
05 Oct 2008 08:38 #240238 by PLUMMEN
its gonna be pretty hard to keep the aluminum parts to seal against themselves for any amount of time without a gasket due to expansion and contraction on a bike that gets ridden more than 1/4 mile at a time ,but id be interested to see if it canbe done.;)
05 Oct 2008 10:49 #240248 by kzr750r1
I hear ya thus skeptical of the method. It's interesting how many options there are out there to tune these motors.
The only way I see this working is if both sides are completely square. To do this both block and cylinder would have to be "worked" on a flat surface...
Mentioning taking 20 or 30 thousandths off the head to decrease squish and increase compression it met with a wince from Derek.
