- Thank you received: 2098
Lets Talk about Oil Cooler brackets
Patton,
American Classix used to carry something I recall, but I couldn't find it on their site. I think they originally came from Klasmo part # 39062300Z . American Classix had a better picture.
Hope this helps a little. The long bolt goes thru the existing sleeve throu your frame just in front of the horn. Then the flat spot on the two aluminum chunks are tap so you bolt the oil cooler to them.
Later, Doug
Thanks, Doug!
That's it!
- MFolks
- Thank you received: 540
- galaxian
1977 KZ1000A1, 1979 KZ650 C3
- zombiescustoms
- zombiescustoms
ebay # 270281201810
- galaxian
the bike looks great can you get a closeup of the mounting bracket? I have an old Long oil cooler actually made for Kerker years ago.
- zombiescustoms
- kawboy13
- zombiescustoms
I used a J C Whitney trans cooler (12 plate, their smallest)trimmed the top bracket then drilled & tapped holes to mount the the top part. For the bottom I used alum. flat stock for brackets and held the cooler away from the frame and tried to match the angle of the cyls. It came petty close. to see how it looks check the KZ 1000 gallery pics 684 - 688. Hope that helps some.
That is also a Long cooler! Same one as on my bike, I have been hard pressed to find a better one, that doesn't get a chewed op bt flying debris! I think you could almost hit thoes things with a hammer and it wouldn't hurt them!
- galaxian
