Lets Talk about Oil Cooler brackets
- galaxian
1977 KZ1000A1, 1979 KZ650 C3
- MFolks
- Thank you received: 540
- keith1
- Thank you received: 2
it fits where the reflector used to be and the bolt above the reflector if for the upper part and
that bolt goes through the frame....i m guessing this is from back in the day cause the cooler and mounts are one piece and it fits like a glove...i havent seen any for sale similar in my online travels.....
- keith1
- Thank you received: 2098
Can someone who has mounted an oil cooler on a 900/1000 post a pic of how they mounted the actuall cooler on the frame?? Or if you have place that sell the bracket post the link.
Here's one way using two eye-bolts to hold a fabbed plate with cooler bolted to the plate.
[Click on image to enlarge view]
AND the other side - - -
Here's a Z1 version using two eye bolts without a bracket.
Patton wrote:
Other side of Z1 version using two eye bolts without a bracket.
Will attempt to locate the pro version and post any info found.
- School Teacher
well my friend has a kz with a cooler off a 900gpz ninja
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- StreetfighterKz
- Thank you received: 117
American Classix used to carry something I recall, but I couldn't find it on their site. I think they originally came from Klasmo part # 39062300Z . American Classix had a better picture.
Hope this helps a little. The long bolt goes thru the existing sleeve throu your frame just in front of the horn. Then the flat spot on the two aluminum chunks are tap so you bolt the oil cooler to them.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
I do recall seeing within the last couple of years a professionally made forged aluminum "bracket" being sold out there somewhere. And it looked techno cool all right, but a little clunky in comparison to the Simple Simon versions. And not within my ability to copy.
Was unable to locate the "professionally" made oil cooler mount, so will describe it from distant memory.
Two fairly thick aluminum pieces shaped like toy car tires are used instead of the eye bolts. And the little aluminum "tires" are held in place just like the eye bolts (a long screw through the oem frame hole used like an axle with a "tire" on each end.)
So at this stage, there's just a little aluminum "tire" on each side of the frame hole instead of an eye bolt on each side.
Threaded holes were tapped into the "tread" portion of the aluminum "tire" pieces whereby the cooler could be mounted with two bolts through the cooler into the tapped holes threaded into the "tread".
I perceived no advantage compared to the simple eye bolts, and the eye bolts afforded as much or more leeway in mounting.
Good Luck!
