Lets Talk about Oil Cooler brackets
29 Sep 2008 13:30 #239249 by galaxian
Lets Talk about Oil Cooler brackets was created by galaxian
Can someone who has mounted an oil cooler on a 900/1000 post a pic of how they mounted the actuall cooler on the frame?? Or if you have place that sell the bracket post the link.
1977 KZ1000A1, 1979 KZ650 C3
29 Sep 2008 14:38 #239262 by MFolks
Replied by MFolks on topic Lets Talk about Oil Cooler brackets
If you can find a wrecked 82 GPZ1100 B2 it will have everything you need. Try at www.oldkawman.com
29 Sep 2008 15:20 #239269 by keith1
Replied by keith1 on topic Lets Talk about Oil Cooler brackets
i dont know if this will help, but heres mine....
it fits where the reflector used to be and the bolt above the reflector if for the upper part and
that bolt goes through the frame....i m guessing this is from back in the day cause the cooler and mounts are one piece and it fits like a glove...i havent seen any for sale similar in my online travels.....
29 Sep 2008 15:21 #239270 by keith1
one more pic
29 Sep 2008 15:26 #239271 by Patton
Replied by Patton on topic Lets Talk about Oil Cooler brackets
Here's one way using two eye-bolts to hold a fabbed plate with cooler bolted to the plate. :)
[Click on image to enlarge view]
29 Sep 2008 15:29 #239273 by Patton
AND the other side - - -
29 Sep 2008 15:35 #239275 by Patton
Patton wrote:
Here's a Z1 version using two eye bolts without a bracket. :)
29 Sep 2008 15:38 #239276 by Patton
Patton wrote:
Patton wrote:
Other side of Z1 version using two eye bolts without a bracket. :)
29 Sep 2008 15:46 #239278 by Patton
I do recall seeing within the last couple of years a professionally made forged aluminum "bracket" being sold out there somewhere. And it looked techno cool all right, but a little clunky in comparison to the Simple Simon versions. And not within my ability to copy.
Will attempt to locate the pro version and post any info found. :)
29 Sep 2008 16:53 #239286 by School Teacher
Replied by School Teacher on topic Lets Talk about Oil Cooler brackets
ZIP TIES BABY!
well my friend has a kz with a cooler off a 900gpz ninja
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
29 Sep 2008 16:59 #239290 by StreetfighterKz
Replied by StreetfighterKz on topic Lets Talk about Oil Cooler brackets
Patton,
American Classix used to carry something I recall, but I couldn't find it on their site. I think they originally came from Klasmo part # 39062300Z . American Classix had a better picture.
Hope this helps a little. The long bolt goes thru the existing sleeve throu your frame just in front of the horn. Then the flat spot on the two aluminum chunks are tap so you bolt the oil cooler to them.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
29 Sep 2008 17:13 #239294 by Patton
Was unable to locate the "professionally" made oil cooler mount, so will describe it from distant memory.
Two fairly thick aluminum pieces shaped like toy car tires are used instead of the eye bolts. And the little aluminum "tires" are held in place just like the eye bolts (a long screw through the oem frame hole used like an axle with a "tire" on each end.)
So at this stage, there's just a little aluminum "tire" on each side of the frame hole instead of an eye bolt on each side.
Threaded holes were tapped into the "tread" portion of the aluminum "tire" pieces whereby the cooler could be mounted with two bolts through the cooler into the tapped holes threaded into the "tread".
I perceived no advantage compared to the simple eye bolts, and the eye bolts afforded as much or more leeway in mounting.
Good Luck! :)
