Supercharger Info - Drouin Roots Type
- jus1975
- www.tripleaperformance.com
- jus1975
- Limey
- 3 Years in the U.K. - Brought the KZ with me!
It does have a vacuum operated device that bypasses the blower at idle/low throttle. This helps the idle issue, as well as fuel consuption at steady throttle, but it does add bulk to the intake manifold and may not be practical on a bike. I "think" the blower is the M90 model!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
- zippy
Hey Zippy, How about some updates. Have you finished your restoration.
Sorry to take so long to reply. I don't check this site that often.
Anyway - my project is just about done. I have been toot tooting around around the area for the last month shaking out any little bugs before I paint the final body parts. About the only thing left to do is polish everything up again, shoot some paint and then take some final pictures. I probably won't get to the polishing this week as it is about 90 - 95 deg. this week and that's a little hot for me to be workin on the bike outside.
It's been quite the adventure trying to remember how to set every thing up as most of the stuff on the bike is about 25 - 30 years old and I'm that much older too No problems setting up the Hahn BHP ignition (an incredibly elegant ignition with vacume retard)but I did have to bone up again on the Hilborn constant flow mechanical injection system. A few calls to Hilborn and Kinsler and some head scratching and some trial and error solved most of the problems. I've added some extra circuitry to the fuel delivery system (Kinsler hi and low speed bypass valves), a new Kinsler rotary jet selector that allows me to adjust main jet fuel mixture on the fly with a twist of the selector and a fuel pressure gauge. Had to figure out how to route everything as well as how to stuff everything under the seat in an unabtrusive way. Also did some relocation of the battery so that it now bolts under the bottom of the seat. I'll have to see a little more how it works, but so far it seems OK although it was kindof a pain when I was adjusting the fuel system.The only thing I still might do is redo the instrument panel and try to update it a bit. Don't know if I can go to a digital display with all mechanical tach, speedo output.
As far as running goes - as you might expect - it runs like a freakin bat outa hell. Waaaaaaay too much power for the present rear end (Macintosh adjustable 10 inch extended swing arm with WM6 rim), but I figure it will keep me outa trouble that way Right now - the bike comfortably idles at around 1000rpm without too much problem but I had to really play around with it to balance all the different fuel circuits. As I still have the cut off drag pipes on it - it sounds ungodly beastly even with the individual baffles installed.
As soon as I do the final polish and shoot the final paint - it goes on ebay for a reserve of $ 10K so start saving those pennies
I'll try and get some recent pictures this week for you guys.
Zippy
- jus1975
- kelarc
- 1977 KZ1000A Drouin Supercharged
- supercharged
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
- zippy
I also forgot in my previous post that I had pulled off the Kinsler high and low speed bypass fuel circuits for now. I'll probably put them on later if needed. So far so good though.
Body parts need painting
Final polishing of aluminum parts (i.e dyno, blower, cam covers, etc.)
Reroute main fuel jet return bypass hose (the one sticking out on the right side
Small touch up paint on engine cases, frame, etc.
Replace or polish some hardware
Install chain gaurd
Clean up and hide wiring
Finish licence plate bracket
Shorten rear brake hose
Rethink instrument panel
Maybe relocate battery so that I can use velocity stack on injector - no big deal though - I've also got air cleaner for either setup
Other than that - it's pretty much ready to go (unless I left something out
- zippy
- zippy
- zippy
- zippy
