Supercharger Info - Drouin Roots Type
  • zippy
  • zippy's Avatar
Re: Supercharger Info - Drouin Roots Type
03 Aug 2008 18:14
#229947
And another
  • zippy
  • zippy's Avatar
03 Aug 2008 18:16
#229948
And another
  • zippy
  • zippy's Avatar
03 Aug 2008 18:17
#229949
And another
  • zippy
  • zippy's Avatar
03 Aug 2008 18:18
#229950
And another
  • zippy
  • zippy's Avatar
03 Aug 2008 18:20
#229951
And another
  • zippy
  • zippy's Avatar
03 Aug 2008 18:21
#229952
And another
  • zippy
  • zippy's Avatar
03 Aug 2008 18:22
#229953
And lastly - thank god
  • zippy
  • zippy's Avatar
03 Aug 2008 22:55
#230013
OK - Here is a picture of my other bike :)
  • jus1975
  • jus1975's Avatar
  • www.tripleaperformance.com
04 Aug 2008 07:14
#230045
That looks l=more expensive than the Z1r. What does the intake manifold look like on the Z1R.
  • zippy
  • zippy's Avatar
04 Aug 2008 10:56
#230117
Magnuson intake manifold on the Z1R is a two piece unit. One side bolts to the head, the other side bolts to the blower with a gaskit in between. One of the sides has a blow off valve which is spring loaded and adjustable. Not a waste gate - just a safty precaution in case of a backfire. Backfires are bad on blowers :( It also has a pressure tap so that a hose can be attached and go to a boost gauge or in my case, the ignition to handle boost retard. It also has another boss that I could tap out for another pressure outlet if I needed it.As you can see - the manifold is very thin from back to front unlike some of the more modern turbo manifolds we see on the market today. Not particularly better, just different.
Hope that helps.
