throwing in the towle
- FireFighterRon
well after putting the engine back to gether it will only turn over about 90% of the way then makes a sound like the piston or something it jaming on something .. i have no idea about engines... also have no grauge so what work i do do has to be done all in 1 day...lol.. or befor night time.........i am looking for someone i can take my bike to what wont ****me in the *** with a very high price to get the engine running..... mabe someone who just likes to fix bikes but not looking to get rich..
i am in Niagara Falls, NY 14305
Instructions for riding a KZ1100 1) sit on bike, 2) start bike and idle till warm, 3) pull in clutch, put in gear, 4) release clutch and rip on the throttle, 5)VERY IMPORTANT!!HOLD THE F*** ON!!!, 6) Enjoy!! Side effects may include whiplash, wrinkle free skin and an evil smile resembling the"Joker"
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- enormiss
Mine made a nasty sound when I was trying to get it running, it had sat for years prior to my purchase.
It would turn over and a bit then make gringing, crashing, banging metalic sounds.
After I got it running for abit and changed the oil it starts up fine.
Reading others threads I'm assuming it was the starter clutch.
Maybe your's is as well and will be OK after a bit of running.
81 750 LTD
96 DR 350
94 DR 350
S. Jersey
- kawsakiman
- Thank you received: 6
or if you want, i can pm you a couple shops in buffalo.
there is always fast by gast on grand island but it will cost you.
now my question to you is
did you take anything in the motor apart or just remove it from the frame?
- kztinkerman
- FireFighterRon
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- FireFighterRon
- wiredgeorge
- kawsakiman
Something had to fall into the valve cover. :
i agree.
were you missing any bolts and used another one instead?
i would pull the cover again and look around.
then try to turn it with the cover off.
see if anything is binding up.( well that you can see )
maybe a cam end plug shifted or something.
it is not unheard of for a bolt from somewhere else to fall in when you were tugging on the motor to remove it.
- FireFighterRon
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
