Bike won't start after rebuild
- nebx
I just finished rebuilding my '79 KZ650, new rings, used head assembly, and gaskets but now I can't get it to start. The engine timing seems to be 180 degrees out of rotation, and I'm getting a backblow through the carbs (backfire, but no explosion). I followed the Clymer manual closely while doing the rebuild. I made sure that the 1 and 4 cylinders were at TCD, installed the cams making sure the "T" marks were pointing to the top surfaces of the cylinder head, and counted the chain pins per the manual. At this point i'm just looking for some advice on what I can do to get it running. Any suggestions?
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
1980 KZ500 B2
- nebx
- SPARKY47
- 1980 KZ500 B2
I personally detest clymer manuals, get a real one, it's worth it:)
1980 KZ500 B2
- nebx
- bountyhunter
- Thank you received: 337
It looks like it can only go on one way, with the wire being at 7 o'clock and the hole in the case matching it. I'll have to take another look at it I guess.
I think you can get it 180 out if the coil wires to the points are reversed or if the cam on the crankshaft is reversed.. I believe one set of points fires the 1-4 and the other fires the 2-3 cylinders?
- tjhiggin
- Thank you received: 1
Based on your description, it's likely not the valves, but worth a check if everything else seems correct.
Good luck.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
- shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- Sandy
- Fly High,Tony
- Thank you received: 13
If you took it apart to clean it,you might have put the lobed section of it back on 180 out.
This doesn't mean that someone ELSE before you,didn't take it apart though.(never assume).
1977 KZ1000 A-1
- nebx
EDIT::
I'll have to get the shop manual. Also, since I didn't actually remove the advancer would you guys still suggest rotating it?
No I haven't adjusted the valves yet. I'll read up on how to do it.
- gpzrox
I can testify that it doesn't hurt anything but pride.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- Thank you received: 2098
Looking under the points cover, the lefthand points or module signals whichever coil is firing both outside plugs, and the righthand points or module signals the other coil firing both inside plugs.
Good Luck!
