engine rebuild problem: valve "slap"?
- Bicycle Lee
I would probably have to replace both sets of valves, right? If so, then I'm looking at 30-40 dollars PER cylinder. That's just for valves. Not to mention the stem, seats, etc...
1978 KZ1000 police
- wiredgeorge
- wiredgeorge
- RonKZ650
- Thank you received: 240
- Bicycle Lee
I know the valves are bent thanks to the air test... but I figured I could at least TRY and assemble the thing correctly and see if the same clicking happens...
1978 KZ1000 police
- wiredgeorge
If you don't follow the eBay link and get one there and replace the valves, remember that you will need to disassemble each valve train and grind the new valve to the proper length. You do this buy using a special machine which makes sure the top of the valve stem is flat... it holds the valve and spins a wheel around it if I remember correctly. You must take off enough so that valve clearances can be within the specified range. The seats need to be dressed. The old valve and new will NOT sit exactly the same in the seat. A machinist calls this issue concentricity (wow I remembered that word!). They can usually dress the seat with the last of the three cutters but some may want to do a valve job. That will be using all three cutters which cut at different angles. It might be a good time to replace the valve guides since it is at a machine shop. Of course, replace the valve seals.
I would also caution that you might want to ask the shop manager at your favorite bike shop or a couple manager where the local machinist is. Most car machine shops are kind of ham fisted with bike bits and don't do all that well... they might do a good job, but not as likely as if you use the shop recommended by your bike shop folks. There is usually only one or two decent bike machinists even in a very large city.
- RonKZ650
- Bicycle Lee
On mine it seems like only the exhaust valves are bent... when doing the air test it didn't seem like the intakes leaked...
I'm looking on APE's site and I'm curious what service I'll need...
Performance (std size) valve job - 8 valve head?
Install bronze valve guides - labor only - 8 valve head?
1978 KZ1000 police
- Bicycle Lee
1978 KZ1000 police
- NickW900LTD
- Nick
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
- BSKZ650
- Thank you received: 14
in his price does that include bench shimming the valves?
77 ltd1000, current rider
76 kz900, just waiting
- APE Jay
- Banned
- Thank you received: 58
I emailed the Old Kaw Man to see if he had a head for sale.... he told me to just send the thing to APE as it would be cheaper in the long run.
That is what most old Kaws need. Add the valve guides and seals.
Jay
