engine rebuild problem: valve "slap"?
- Bicycle Lee
1978 KZ1000 police
- steell
If not, then it's probably the pressure of the valve springs on the cams making them "snap" until they take up the slack.
Now if you're saying there is lots of clearance between the valves and the cams, and then the valves suddenly release and smack the cam, then the only thing I can think of at the moment that would cause this is bent valves.
- Bicycle Lee
so, we tried removing the cams again, making sure the cams were correctly positioned and the valve shims well-lubed... same thing. The sequence of "slapping" is: #1, #2, #4 and #3.... all on the exhaust side. The intake side seems to not be doing it.
I wouldn't think that it were possible that the valves became bent while the cylinder head just sat there. I cleaned them but that's it.
Help!!! I'm SO close!!!
1978 KZ1000 police
- Bicycle Lee
1978 KZ1000 police
- steell
When you removed the tensioner, did you retract it all the way and tighten the lock bolt to keep it retracted? And, did you loosen the lock bolt to let the tensioner take up the slack and then re-tighten it after installation?
- Bicycle Lee
1978 KZ1000 police
- steell
I don't have a manual that covers you bike, but if I recall correctly you just loosen the lock bolt so the spring loaded tensioner can take up the slack, then re-tighten the lock bolt.
Maybe someone else with a manual will chime in, my memory is a little rusty so I may be wrong, I sold my 77 KZ1000 in 1982 so it's been awhile
- wiredgeorge
- Bicycle Lee
I will tinker with the tensioner and get back to you all.... thanks so far...
1978 KZ1000 police
- FastKaw1
One cam at a time. DO NOT put in both cams in when
bench setting. Make sure you have the head shimmed
off the bench 1/2 in. or more.
As you turn the cam you will be abule to see just
what is going on with the valves.
If you cleaned all the carbon of the head and valves
your valve clearance is probably way off.
If you benched the head and did not shim the head of the
bench you most likely bent a valve or two.
Good Luck
XENU
- larrycavan
- Visitor
At TDC of 1 & 4 cylinder the exhaust valves of 2 & 3 "slap" up against the cam lobes, and vice versa at TDC of 2 & 3. Anyone have any ideas????
If you have valves that are actually pressure loaded then suddenly breaking free of the pressure and the buckets fly up, slamming the shim against the base circle of the camshaft....causing a noise.....STOP! You have something seriously out of wack and there's probably damage done.
That scenario is not the same as simply having tight valve clearances. Which is it?
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
