engine rebuild problem: valve "slap"?
  • Bicycle Lee
  • Bicycle Lee's Avatar Topic Author
Re: engine rebuild problem: valve
26 Jun 2008 16:16
#222375
I have seals that came with my gasket kit, so I'm definitely using those. And yes the labor quote included bench shimming the valves.
1978 KZ1000 police
  • Bicycle Lee
27 Jun 2008 14:46
#222559
so I will undoubtedly need new shims after I get my valves done, right? But I won't know what size until it's all said and done, correct?
1978 KZ1000 police
  • FastKaw1
  • FastKaw1's Avatar
27 Jun 2008 15:20
#222566
Your head should be real close when it comes back.
Bolt it up. check the shims, if close run it. Run motor up to norm. operating temp.
and shut it off. I what 12 to 24 Hr. and check the shims again.
After that you should be good to go.
