darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
- downhandonly
22 May 2008 20:00 #215229
by downhandonly
80 KZ1000 LTD
Replied by downhandonly on topic darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
hey guys got the heli coil in and the proper torque on the bolts this time! also got the old smog ports off and my new handmade aluminum block off plates on the valve cover! yehaw!! thanks for the help everyone!!
80 KZ1000 LTD
- letthegoodtimesroll
- Thank you received: 1
20 Jun 2008 15:15 #221195
by letthegoodtimesroll
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
Replied by letthegoodtimesroll on topic darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
I now have my head and cylinders off and I was thinking, could I get longer 6x1 bolts cut the head off and clean up the threads and locktite them into the holes and then fasten the camcaps down using nuts? I would use 2 nuts on the "stud" to put them in. I just hate taking those bolts out and in. Thoughts?
- RonKZ650
- Thank you received: 240
20 Jun 2008 16:13 #221203
by RonKZ650
Replied by RonKZ650 on topic darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
The stud idea would work except there is not much room under the cover, so your studs could only extend up about as high as the original bolt head was. Trouble with this is when you bolt in the cams being as they have lobes, the camshaft will be sitting quite a ways off the head surface and I doubt the stud would be long enough to allow threading on the nut. Just helicoil and tighten to only 5.5 ft/lbs (66 in/lb).
20 Jun 2008 17:47 #221223
I already have done the helicoils, I was just thinking of something that I don't have to remove and install everytime I need to adjust the valves.
- kzwolfsr
- Thank you received: 16
09 Nov 2008 12:44 #246492
by kzwolfsr
Original man of the Caribbean
Replied by kzwolfsr on topic darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
ok I did the helicoil trick already and well I dont think I did such a good job, so my camshaft came back up. What else should I do....? Bigger threads? The bolt trick? I was gonna do another helicoil of a rougher thread. Is that ok?
- mark1122
- Keep twisting it
- Thank you received: 109
09 Nov 2008 14:51 #246505
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
Are u saying that the coil stripped out of the hole?
did this happen when u were trying to pull the cam and cap down into place with that bolt?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- gane
09 Nov 2008 16:07 #246516
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
Wolf, I'm not familiar with your' motor, or if the hole your' working on is also a dowel one. but offer these. TIME-SERTS are similar to heli-coil, only instead of winding a bit of square wire into a re-sized hole, insert is a steel inside/outside threaded sleeve. and are avail. in different lengths. If your' cam tower height is sufficient to accept a longer insert, and previous tap isn't totally wasted, you might be able to insert a longer fitting deeper into head, and using a longer bolt come up with a combo which holds proper torque.Luck G
- shighley
10 Nov 2008 06:16 #246606
by shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
Replied by shighley on topic darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
I agree with Gane, TimeSerts are great. I think they make an insert that covers your problem. That is a "second" oversize O.D. thread. The M6x1.0 standard O.D. insert is M8x1.0, which is the so called M6 STI tap. (Steel Thread Insert). After you use a TimeSert, you won't use anything else. The kit costs more than the helical wire ones. The cool thing is that the insert is swaged into the parent material. Ride safe, Steve
www.threadkits.com/timeserts/timeserts_metric.html
