darrrrrn....I have a sstripped cam cap bolt hole!!!!!!!!
- Beatpoet
- RonKZ650
- Thank you received: 240
- Sandy
- Fly High,Tony
- Thank you received: 13
8 FT/pounds is NOT too much for the cam caps.
As long as the threads HAVEN'T been weakened or
stretched from over-torqueing,8 FT/pounds is OK.
Another thing...using FT/pounds would usually mean that you're
using a HUGE torque wrench,when you SHOULD be using a small,
INCH/pound wrench(way less leverage),to get a better "Feeling"
of when that bolt IS tight enough.
You WON'T get that feeling,using a FT/pound wrench on such a
small bolt...period.
1977 KZ1000 A-1
- RonKZ650
- bountyhunter
- Thank you received: 337
That's what I use, about 100 inch-pounds. You need a low-range torque wrench to keep from accidentally over torquing.I totally dissagree with that,Ron.
BTW, the FSM spec for mine is 95 - 110 inch pounds which is about 8 - 9.1 ft-lbs. 100 inch pounds is about on nominal.
- bountyhunter
Bullseye.I totally dissagree with that,Ron.
Another thing...using FT/pounds would usually mean that you're using a HUGE torque wrench,when you SHOULD be using a small,INCH/pound wrench(way less leverage),to get a better "Feeling" of when that bolt IS tight enough.
- bountyhunter
True, the damage is usually done by the last idiot who worked on it and you are the person who applies the right torque and shears off the weakened threads.I'm just used to using the old ft/lb term, since in/lb really wasn't ever used back in the old days. I've got both in/lb and ft/lb torque ratchets though and both give that same insecure feeling on the exhaust caps. Intakes no problem at 8 ft/lb, but exhausts are real iffy. I'm sure it makes a difference how many times the caps have been off too. I know I've stripped them myself at 8 so I'd be careful is all I'd recommend.
- davenkids2001
As far as trying to drill/tap/helicoil this hole I would think it would be better to simply pull the camshaft in question and do the work rather than trying to keep in installed and risk getting any metal shavings under the cam.
Just my 1% for the day.
Dave and Janet
Great Lake State
1979 650SR
- PLUMMEN
- Thank you received: 104
if you look in the area where a set of 4bolt main caps would run the outer bolts there is no meat there,the steel strap is much stronger than the stock cast iron cap and the studs are just cheap insurance.Check out this guy's work... It's called 'doweling and strapping.' He actually oversized *all* of the main cap studs and put a good chunk of steel over each one. He claims 1000hp out of a 4.3L Chevy.
- davel
- Sandy
- Fly High,Tony
So very sad,and so very true!
I hear what you're saying,Ron.
I never thought about the heat-factor,and the "exhaust" cam-caps
being the weaker link.
Gotta wonder now,of all the people that HAVE had the unfortunate
experience of stripping those bolts...
were they intake,or exhaust?:huh:
1977 KZ1000 A-1
- PLUMMEN
