- Thank you received: 797
Heres my clearances, all in spec, whats the ticking?!
01 May 2008 11:43 #210471
by 531blackbanshee
Replied by 531blackbanshee on topic Heres my clearances, all in spec, whats the ticking?!
have you checked the compression?not by seeing if it will blow your thumb off the hole,with a guage.low compression can cause the problems you are talking about.
- BSKZ650
- Thank you received: 14
01 May 2008 12:20 #210477
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Heres my clearances, all in spec, whats the ticking?!
I think you have a lot os issues going on,,
what is the condtion of the battery
since it has not been running I think the carbs need a goog cleaning and adj.
- cuds
02 May 2008 12:26 #210726
by cuds
Erik B
Bay Area, CA
1976 KZ900
Replied by cuds on topic Heres my clearances, all in spec, whats the ticking?!
The battery is brand spankin new.
The carbs are completely rebuilt, once, twice, a thousand times. They aren't clogged and they are together correctly.
Funny thing is, is about 2 weeks ago it was running on 3 cylinders, and was running AWESOME, and I adjusted the points and also adjusted the valves on cyl 2 (cyl 2 was the one that wasn't firing), and every since I got it all back together, it's been having these problems. COuld it be the points possibly? All the vavles are within spec, the tighest one being .003 and the loosest one being .007; I was told the spec was between .002 and .008.
Erik B
Bay Area, CA
1976 KZ900
