Heres my clearances, all in spec, whats the ticking?!
- cuds
26 Apr 2008 19:49 - 26 Apr 2008 19:50
Just checked all my valve clearances, and they are as follows. All are within spec except Cyl 4...
(1E)....(2E)....(3E)....(4E)
.003.....006.....006.....002 DOESNT FIT
(1I)....(2I)....(3I)....(4I)
.006.....006.....005.....012
Now, I know cylinder 4 is out of spec, but the ticking is coming from the left side. Kind of sounds like 2E (2 exhaust) is tapping the piston, but it's not.
Any ideas?
Bike is also a PITA to start cold.
Any ideas?
Erik B
Bay Area, CA
1976 KZ900
Bay Area, CA
1976 KZ900
Last edit: 26 Apr 2008 19:50 by cuds.
- tool maker
Re: Heres my clearances, all in spec, whats the ticking?!
26 Apr 2008 20:31
Quite possibly an exhaust leak, Check and or replace exhaust gaskets, their pretty inexpensive.
Lancaster, PA
82 KZ1000 M2, stage 3 jet kit, pods, 4 into 1 Mac, Accel coils & wires.
- cuds
27 Apr 2008 09:36
OHH LOL. Sometimes I get ahead of myself..
Well, as I said, the bike won't freakin start. I tried and tried and tried, and no luck. So, I checked the things a motor needs to run..spark, air, compression, and fuel. I have spark, air, and compression, can we guess what's wrong?
Yup, I have a carb issue. And it's my fault :DOH:...I'm not using the gas tank because it's getting cleaned right now and I'm also waiting on a petcock...so I have a tube hooked up to the carbs and I'm just feeding gas into that. Well, me being the bright one, I never put a inline fuel filter on for any of this. Oops. Yeah, I drained the bowls on all 4 carbs, and SO MUCH gunk and crud came out, definately clogging the passage ways. I got one carb blown out this morning and it was for sure clogged, I'm going to get the rest done tonight when I get home from work.
Everyone makes the funny mistakes, no? lol
Erik B
Bay Area, CA
1976 KZ900
Bay Area, CA
1976 KZ900
- racer54
27 Apr 2008 11:32
Us? Experts on motorcycle maintenance that we are? Us? Make mistakes? Well.....guys.....ever make any mistakes? I didn't think so! LOL
- Sandy
- Fly High,Tony
27 Apr 2008 12:56
Just don't forget to drain the winter air out of the tires,and replace it with SUMMER air!(common mistake,and so often over-ooked)
1977 KZ1000 A-1
- cuds
27 Apr 2008 13:12
No way dude, it's got the factory air from 76 still in the tires! (seriously, it does)
Erik B
Bay Area, CA
1976 KZ900
Bay Area, CA
1976 KZ900
- coppertales
28 Apr 2008 08:42
I never make mistakes.......I just flat ass screw up......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- N0NB
- Blue handles better
28 Apr 2008 09:05
misteaks? We don't make mastikes!
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- violentvintagecycles
28 Apr 2008 13:02
I thought i was mistaken once.. i was wrong..
- cuds
28 Apr 2008 13:34
No progress on these carbs yet, my girlfriend is taking up all my time. :crazyeyes:
Erik B
Bay Area, CA
1976 KZ900
Bay Area, CA
1976 KZ900
- Six9GS
28 Apr 2008 15:53
Personally,
I prefer to think of things as learning experiences. :laugh: That is until I do the same thing again, when i should have known better. That's reffered to as experience reinforcement!!:woohoo: Otherwise I just refer to 'stuff' as testing the rules of physics.
Haven't broken any of those physics rules yet. Have broken other stuff though....:blink:
Terry!
Terry!
- cuds
01 May 2008 09:20
LOL @ this thread.
But back on topic, I have some more questions.
So, I FINALLY got the bike started, after about 2 1/2 hours of trying. Yes, I know, if it doesn't start after that long, there is somethign wrong. But, I knew it would eventually start and I wanted it to run so I could HEAR how it was running and *try* to diagnose the problem...that being said, here are my symptoms...:
--Bike is EXTREMELY hard to start, even when WARM.
--Will ONLY start with choke ON and FULL throttle, but when it starts, I have to turn the choke OFF other wise it won't stay running. I can hear how rich it's running, its crazy.
--When running, I have to keep it at 1/4 throttle or more, otherwise it will just die
--Won't start with electric start for some reason, not sure why. I can only get it to start by kicking it.
--I tip the bike over each way to drain the carb bowls and then I give it a good kick, it will usually fire up or at least sputter.
Erik B
Bay Area, CA
1976 KZ900
Bay Area, CA
1976 KZ900
