Header Wrap
04 Jan 2008 00:19 #187596 by bkitchen
Header Wrap was created by bkitchen
I am considering wrapping my header. The front of my Kerker is pretty pitted so I figured I could cover it up. I photoshopped some pics because I m trying to decide what color to go with. Let me know what you think. I am leaning towards the tan.
Post edited by: bkitchen, at: 2008/01/04 03:19
04 Jan 2008 00:20 #187597 by bkitchen
Replied by bkitchen on topic Header Wrap
Here is with the black.
04 Jan 2008 00:21 #187598 by bkitchen
Here is without. It actually looks better in the pic than real.
04 Jan 2008 03:27 #187601 by 2M4Dale
Replied by 2M4Dale on topic Header Wrap
I like the looks of the black wrap on your bike, myself ... I've been thinking of wrapping the pitted, old black MAC header on my KZ too.
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • Biquetoast
  • King Jeremy The Wicked
04 Jan 2008 05:05 #187606 by Biquetoast
Replied by Biquetoast on topic Header Wrap
I did black on mine, and will do black on the rest that I do, too.
I suppose you could do tan if you live in a mostly-sunny climate, or accept the consequences otherwise. I mean, around here (Michigan), it would only take one rainy ride to make the middle two pipes on your bike black on the front anyway from road mucky spray... then you'd have a strange looking pattern...
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
04 Jan 2008 07:17 #187627 by kawtoy
Replied by kawtoy on topic Header Wrap
Black for sure. I have done a few bikes and it look killer. It will fade after getting washed a few times but you can just give it a quick spray paint again. Buy the thin white wrap (the wide stuff is too hard to do our header with). Soak it in water for a few hours. Put on some rubber gloves because it is made of fiberglass and itches like crazy. Wrap the pipe from bottom to top so that the wrap is overlapping the correct way. Tie it up with metal zip ties and then let it dry. You can put it on the bike and run it to help it dry. As it dires it shrinks and becomes very tight. After it is dired you can paint it with any high temp paint. You could paint it red if you wanted. It wil take about 4 coats because the paint will soak in a bit but when you are done it will look bitchin
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
04 Jan 2008 08:36 #187634 by Bluemeanie
Replied by Bluemeanie on topic Header Wrap
Kinda leaning with the black myself, goes with the theme of the bike. :)
04 Jan 2008 09:26 #187640 by Bad Kaw
Replied by Bad Kaw on topic Header Wrap
Black.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
04 Jan 2008 18:13 #187689 by jagrider
Replied by jagrider on topic Header Wrap
jagrider here I have a ZX7 with a Zx9 14.5 piston motor on it. I rap the header the motor temp went up 12 degreas it traps some heat in the exhaust system. You my like to install a temp gauge some where along the motor. You can buy small oil temp gauge at any speed shop for cars.Running oil lines around the motor will koss temp to go up to - because when the oil is coming and going it's heating up when the oil lines are close to the motor. Oil lines should be ran on top and mounted to the rails under the gas tank over the motor and then back to the motor. Make sure there a oil pressure gauge 0 to 25 pis install or close to it.
Happy new year :woohoo:
Loud pipes save lives.
  • CoreyClough
  • GPz550 Addiction
04 Jan 2008 19:04 #187698 by CoreyClough
Replied by CoreyClough on topic Header Wrap
Send them out for Jet Hot Coating instead. They'll do the inside and outside. Long term use of header wrap will cause crystalization of the metal.
'85 GPz550(ZX550-A2)
04 Jan 2008 23:20 #187725 by bkitchen
I guess tha blacks have it. I didn't think about the tan getting dirty looking. I wish I had the money to have it jet-hot coated but not in the budget right now.
05 Jan 2008 06:24 #187737 by Bluemeanie
I've heard that wrapping pipes increases thermal efficiency? Whatever that means... :S
