Will exhaust from KZ1000 fit KZ750 ?
03 Jan 2008 06:27 #187471 by Arnold
Will exhaust from KZ1000 fit KZ750 ? was created by Arnold
Hi,
I found a cheap and nice exhaust on Ebay that fits a KZ 1000. Will this fit my KZ 750..with some modifications ?
This is the KZ1000 exhaust:
Post edited by: Arnold, at: 2008/01/03 09:57
03 Jan 2008 06:40 #187472 by Mcdroid
Replied by Mcdroid on topic Will exhaust from KZ1000 fit KZ750 ?
In a nutshell...no. The distance between the header pipes are fixed on the pictured set...this distance differs between 750(4) and 1000's.
Post edited by: Mcdroid, at: 2008/01/03 09:41
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
03 Jan 2008 07:00 #187476 by Arnold
Replied by Arnold on topic Will exhaust from KZ1000 fit KZ750 ?
But if the pipes are adjustable...wouldn´t it be possible to make it fit some how ?
This is my KZ750 exhaust today: (cut off by prev. owner)
03 Jan 2008 07:31 #187484 by Mcdroid
While I haven't measured (and I have a set of 750(4) and 1000 pipes at home) I'd bet the diameter of the head inserts are different. I can measure tonight if no one chimes in.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
03 Jan 2008 08:45 #187489 by Arnold
Ok, that would be nice..
03 Jan 2008 09:53 #187499 by RonKZ650
Replied by RonKZ650 on topic Will exhaust from KZ1000 fit KZ750 ?
The 2 outer pipes are further apart on a KZ1000 than a 750. You can't adjust for that.
03 Jan 2008 12:45 #187516 by wiredgeorge
Replied by wiredgeorge on topic Will exhaust from KZ1000 fit KZ750 ?
That is surprising Ron since the carb spacing is the same. The system pictured has the outside two pipes welded on but the middle two are not... they just sit in the collectors and move. Do you use the same exhaust gaskets on a 750 and a 1000? If so, that would imply the holes in the head are the same diameter.
03 Jan 2008 13:07 #187518 by ten6
Replied by ten6 on topic Will exhaust from KZ1000 fit KZ750 ?
To change the distance of the outer pipes, simply cut and reweld the balance tube between them...shortening it...B)
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
03 Jan 2008 13:46 #187529 by RonKZ650
The intake side spacing is the same, the exhaust spacing is not. The brass rings that seal the pipe to the head are also smaller diameter on a 750 than a 1000. I doubt that even if you could bend the KZ1000 system to align with the 750 exhaust ports the pipes would be able to be installed.
03 Jan 2008 15:12 #187538 by dannyg40
Replied by dannyg40 on topic Will exhaust from KZ1000 fit KZ750 ?
I owned a 750 and now a 1000. There is a big difference in the size of the 1000 pipes. Even the way they mount to the exhaust manifold is different.
04 Jan 2008 04:24 #187604 by Mcdroid
Even though you probably have your answer, the OD (terminal lip) measurement on a KZ1000 kerker header exhaust pipe is approximately 42mm while that of a MAC KZ750 exhaust pipe is approximately 38mm.
Post edited by: Mcdroid, at: 2008/01/04 07:25
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
04 Jan 2008 07:57 #187631 by jonnybiker
Replied by jonnybiker on topic Will exhaust from KZ1000 fit KZ750 ?
Food for thought......Anything can be made to fit/work ...if determined or stuborn enough to do what is nessasary to acomplish your goal. Cost , work involved , and time spent are the only real limiting factors. that said.....pipes are fairly cheap....why bother with a project like this???? take care all..jonnybiker
