Will exhaust from KZ1000 fit KZ750 ?
  • Arnold
  • Arnold's Avatar Topic Author
03 Jan 2008 06:27
#187471
Hi,
I found a cheap and nice exhaust on Ebay that fits a KZ 1000. Will this fit my KZ 750..with some modifications ?
This is the KZ1000 exhaust:
Post edited by: Arnold, at: 2008/01/03 09:57
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Will exhaust from KZ1000 fit KZ750 ?
03 Jan 2008 06:40
#187472
In a nutshell...no. The distance between the header pipes are fixed on the pictured set...this distance differs between 750(4) and 1000's.
Post edited by: Mcdroid, at: 2008/01/03 09:41
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Arnold
03 Jan 2008 07:00
#187476
But if the pipes are adjustable...wouldn´t it be possible to make it fit some how ?
This is my KZ750 exhaust today: (cut off by prev. owner)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
03 Jan 2008 07:31
#187484
While I haven't measured (and I have a set of 750(4) and 1000 pipes at home) I'd bet the diameter of the head inserts are different. I can measure tonight if no one chimes in.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Arnold
03 Jan 2008 08:45
#187489
Ok, that would be nice..
  • RonKZ650
  • RonKZ650's Avatar
03 Jan 2008 09:53
#187499
The 2 outer pipes are further apart on a KZ1000 than a 750. You can't adjust for that.
  • wiredgeorge
  • wiredgeorge's Avatar
03 Jan 2008 12:45
#187516
That is surprising Ron since the carb spacing is the same. The system pictured has the outside two pipes welded on but the middle two are not... they just sit in the collectors and move. Do you use the same exhaust gaskets on a 750 and a 1000? If so, that would imply the holes in the head are the same diameter.
  • ten6
  • ten6's Avatar
03 Jan 2008 13:07
#187518
To change the distance of the outer pipes, simply cut and reweld the balance tube between them...shortening it...B)
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
  • RonKZ650
  • RonKZ650's Avatar
03 Jan 2008 13:46
#187529
The intake side spacing is the same, the exhaust spacing is not. The brass rings that seal the pipe to the head are also smaller diameter on a 750 than a 1000. I doubt that even if you could bend the KZ1000 system to align with the 750 exhaust ports the pipes would be able to be installed.
  • dannyg40
  • dannyg40's Avatar
03 Jan 2008 15:12
#187538
I owned a 750 and now a 1000. There is a big difference in the size of the 1000 pipes. Even the way they mount to the exhaust manifold is different.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
04 Jan 2008 04:24
#187604
Even though you probably have your answer, the OD (terminal lip) measurement on a KZ1000 kerker header exhaust pipe is approximately 42mm while that of a MAC KZ750 exhaust pipe is approximately 38mm.
Post edited by: Mcdroid, at: 2008/01/04 07:25
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • jonnybiker
  • jonnybiker's Avatar
04 Jan 2008 07:57
#187631
Food for thought......Anything can be made to fit/work ...if determined or stuborn enough to do what is nessasary to acomplish your goal. Cost , work involved , and time spent are the only real limiting factors. that said.....pipes are fairly cheap....why bother with a project like this???? take care all..jonnybiker
