[CAMCHAIN] It can't rivet it !
- Conti
I'm having some trouble to put a new camchain into my KZ1000ST engine.
I bought a chain (EK 219H x 124), and opened it since I planned to rivet after having installed it in the engine.
However, I can't rivet properly that damn chain.
Here's a picture :
Of course, I removed the 2 plates installed on the chain. I then inserted the piece which one can see on the top of the picture. And then, I tried to install the plate (bottom right).
The sideplate (which is an EK) can't even be installed on the rivets. I tried to use this tool :
However, I can't press the sideplate enough into the link.
What could I do ? Any advice ?
I didn't installed an "non-opened" chain, because it's an ST : shaft-drive.
- tjettim
- Thank you received: 2
showing on both ends.Then the rivet link
goes through both rollers(males) and then
the cover plate goes on,then you stake the rivet.
- The Milkman
- Thank you received: 194
The chain has to have a roller (male) end
Yeah, both ends of the chain need the piece that I tried to put in the rectangle on the ends for the master link to fit.
- steell
Post edited by: steell, at: 2007/09/04 20:25
- Conti
I took the picture before removing those parts.
The problem is that I can't insert the spare (new) sideplate onto the spare link, shown on the picture.
- wiredgeorge
- tjettim
plate and super glued two old plates to the outside
of the press on plate.I then used a large c-clamp
to press the pins through the plate.Then pryed off
the glued on plates and then staked the rivet heads.
- brianrae33
1982 kz1000ltd
- Conti
I pressed the plate onto a new link, and then the pins moved the other side. Look at this, I hope it's clearer like that (my English sucks) :
The link moves freely. The plate doesn't move : it is strongly attached to the links.
However, I'm a bit worried. I wasn't able to rivet the 2 pins. There's not enough room to do that (on the left). Moreover, as I said, the pins went to the right.
Do you think it's ok ? Of course, I don't ask for a definite reply. I just would like your opinion. If you say it's ok and it breaks, well, that's life.
I could use the C-pliers to try to put the links back to the middle. However, I'm almost sure if I do it, the link won't move freely, and I think that wouldn't be good at all...
- Thank you received: 2829
- steell
I would NOT run it if the master link cannot be riveted. If it comes apart it will make a mess out of the engine, and if you're in the middle of a high speed turn, it may make a mess out of you. Why not just buy another master link and start over? Ed
Totally correct, don't even think about riding that bike until you fix it right.
The ER will be waiting :woohoo:
- JimatMilkyWay
- Thank you received: 12
I agree with everyone else. You are obviously _NOT_ spending your savings on cat food, so you can spring for a new master link. You sound like a pretty sharp guy to me. If you closely study the master you installed, and can see _ANY_ variation in the spacing or appearance of it, compared to the rest of the chain, then it ain't safe to run.I would NOT run it if the master link cannot be riveted. If it comes apart it will make a mess out of the engine,...
The only thing I might suggest different from what I have read here, is to use a tiny socket as a "ram" and pliers or vise grips to press the side plate into proper position. First, get it started on both ends of the master, then press one side then the other, a little at a time, till fully seated. Stake it last. Does that make sense?
Post edited by: JimatMilkyWay, at: 2007/10/15 19:36
Post edited by: JimatMilkyWay, at: 2007/10/15 19:39
