Break in
- larrycavan
- Visitor
IMPORTANT THING YOU WANT TO DO after you run it the first time is to RETORQUE THE HEAD...Run it, let it get completely stone cold, then retorque the head.
After that...whatever method you choose to break in the engine is up to you but MAKE DAM CERTAIN YOU RETORQUE THE HEAD..
- OpenRoad
- baldy110
- Thank you received: 512
All my engines have lasted a very long time with great performance and without using oil using this style of break in. If you baby the enigne you WILL have problems with it using oil and it will NOT perform as it should.
Oh yeah I also try and find the oldest 30 weight oil I can find and use it for break-in. I have found the new multi vescosity oils are to good and I have had to re-ring several engines due to the newer oils not allowing the rings to seat properly. I buy all the older 30 weight oil I can find just for engine break in.
Post edited by: baldy110, at: 2007/08/09 11:16
- OKC_Kent
- Thank you received: 20
I break all my engines in hard. ........
Post edited by: baldy110, at: 2007/08/09 11:16<br><br>Post edited by: baldy110, at: 2007/08/09 11:16
Are you just using straight 30w? And how old is old oil, what rating is it?
I agree about a hard break-in too.
Thanks
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- OpenRoad
- baldy110
For whatever reason I have found the rings seat better with straight weight oils. I have two cases left of very old valvoline 30 weight in cans no less, that I use for break in. Don't know what I am going to do when I run out.
- themachine
- Thank you received: 4
Wiseco rings and pistons. This is not an unusual way to break in engines. It's used by top engine builders also and airplane piston engine maufactures. Babying a fresh engine is the worst thing you can do it. My last KZ650 engine had about 148,000 miles and was still running great and not using much oil. I rebuilt it simply to install a big bore kit. This method works.
try rottela deisle oil, it has more nickel and anti wear additives that others, and it comes in high grades too.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- baldy110
I have tried to break in our older engines on the the newest wazzoo oils and have had to tear the engines down and re-ring them again due to high oil consumption and low power.
Ok, I'm done now.
- cottoncandyninja
- GPzephyr
- Thank you received: 1
Make sure if you have an oil cooler that after you run the engine for the very first time, check the oil level before going out. The cooler and pipes usually take a reasonable amount of oil out of the sump. Don't want to run low on your first trip.
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
- OpenRoad
- themachine
same stuff you want to run in a muscle car with a fresh engine, my machine shop reccomended it for breakin oil, and they do mostly high performance engines ranging from 2-stroke dirtbikes to alcohol strip motors so i trust their judgment, my motor broke in great on the stuff.
