Break in
- nads.com
Re: Break in
01 Oct 2007 22:06
I second the motion, "RETORQUE the head". The gaskets settle. I read some test reports where they took a bunch of new bikes and broke half them in real hard and half real nice. The result was very close, the ones that were beat had slightly better compression. I just rev it up to around 4 a few times and then to 6 a few. The rapid piston speed begins to seat the rings right away. After doing that, it doesn't matter what you do. They will be seated already or will seat within a few miles. I would do this before adjusting any thing, shut it off and make some adjustments, let it cool for an hour with a fan blowing on the front of the enine. 100 miles down the road later on, let it cool and torque the head again, it's going to be loose again. You can check the torque at 40, 60 80,100+ miles, doesn't matter. If it's loose when you check it, torque it again and it will problably be the last time you have to do it. Running the motor without torqueing, it will leak oil and pound out the base gasket. I've had motors do that to the extent the base gasket had to be trimmed three dfferent times, and was lucky it didn't leak. It's ok to torque after first start up to, just make sure to check it one last time later on.
Post edited by: nads.com, at: 2007/10/02 01:09
- StreetfighterKz
Re: Break in
02 Oct 2007 04:20
www.brockracing.com/tech_breakin.htm
Check out this link. This article was run in Motorcycle Performance years ago. It has some really good tips from the first guy to take a street bike into the 7's in the 1/4 mile.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- jordan172005
Re: Break in
02 Oct 2007 19:05
back about 2 yrs ago I took some racers advice on breaking in my moped engine. The engine was built for racing and did about 55mph. He said just ride it like you normally would and it'll be fine. We'll I rode the balls off of it and went through 3 engines in a week. So now I take it easy on mopeds and motorcycles about the first 200mph and then ride it like I stole it. I haven't blown an engine and everything has been running well.
- jordan
Re: Break in
02 Oct 2007 21:25
The guy at my local autoparts store told me he recommends non-synthetic 20-50w oil. Is this okay?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- GPzephyr
Re: Break in
05 Oct 2007 14:52
Yup!
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
- themachine
Re: Break in
05 Oct 2007 15:13
jordan wrote:
ezactly what i run, i use rottela diesle 20w50 dino oil.
at 2.40 a quart you cant go wrong
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- JimatMilkyWay
Re: Break in
06 Oct 2007 14:11
jordan172005 wrote:
I have always advised folks to keep their mopeds below 200mph whenever possible!:woohoo: :woohoo:
That is really _REALLY_ good advice!... So now I take it easy on mopeds and motorcycles about the first 200mph and then ride it like I stole it...
