KZ750 vs GPZ750
  • jackieray
  • jackieray's Avatar Topic Author
KZ750 vs GPZ750
19 Apr 2007 08:44
#131828
Long story short my KZ 750 motor is shot. The repair shop said they had a couple of KZ 750s in stock. I just got off the phone and they said that both of them have problems, but they have a GPZ 750 that is in real good shape that they can put in. What is the difference between them. Should I let them or see if I can find a KZ?
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
Re: KZ750 vs GPZ750
19 Apr 2007 09:06
#131840
Ooooh, baby! Do not hesitate! The one thing every bike needs is factory-reliable HP. ;)
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • anarki650
  • anarki650's Avatar
Re: KZ750 vs GPZ750
19 Apr 2007 09:06
#131841
I don't know a ton about the differences between the basic 750 and the gpz, but I do know that the gpz is a more powerful engine with different cams and slight porting on the head (stuff I've read in other posts). So, if you can get that gpz motor in without spending a ton more money I'd say go for it!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: KZ750 vs GPZ750
19 Apr 2007 09:22
#131844
What they said! One of the tech reviews I read quite some time ago said the original reviewers of the genesis of the 750 GPz line (KZ750R1) thought that Kawasaki had done some motor work to the head to give the reviewers a non-standard bike...turns out that all the 1982 GPz750 heads were ported/polished:) 80hp stock...should eat a stock Z1/KZ900/early KZ1000 for dinner
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
Re: KZ750 vs GPZ750
20 Apr 2007 09:20
#132237
Definitely if they can also supply the gpz carbs, but I guess if they have the low mileage motor, I would still go for it!!
Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • apeman
  • apeman's Avatar
Re: KZ750 vs GPZ750
20 Apr 2007 09:37
#132244
Grab that GPZ engine before someone else finds it! View it as an improved, slightly hopped-up version of the KZ750 engine. I would do it in a flash.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • 77KZ650
  • 77KZ650's Avatar
Re: KZ750 vs GPZ750
20 Apr 2007 12:29
#132299
I agree with everyone else. get the gpz. factory mild porting, .5 more compression ratio pistons (kz=9:1 gpz=9.5:1) better cams (higher lift and more duration) so more hp, you cant go wrong if its in good running order:evil:
07 MDP Rookie of the Year
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
Re: KZ750 vs GPZ750
20 Apr 2007 15:31
#132340
Go get it ;)
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • jackieray
Re: KZ750 vs GPZ750
01 May 2007 19:08
#136251
Well It runs like a bat out of hell!!! I thought I was going to put down the street but ohno I need a new tach (electronic), and bigger carbs (saving my pennies) Now for the help question. When I get the RPMs up I feel a good amount of vibration in the front of the bike, and the needle on the speedo drops to 0... as soon as I shift the needle shoots back up to where it should be. I thought that the vibration could be coming from the oil cooler (no mounting bracket on the bike), but I have secured that down with some hose clamps it is not going anywhere. I am going to take back to the shop this weekend but would appreciate some advice as to what might be causing this anomaly. Also the #3 exhaust pipe is psting a little when the bike is cold it goes away as the bike warms up. The shop told me about it before I left and said they had tried to fix it to no avail.
Thanks for all your advice...you guys rock
  • 77KZ650
  • 77KZ650's Avatar
Re: KZ750 vs GPZ750
01 May 2007 19:54
#136281
you could try doubling up the crush gaskets for the exhaust, they arent really reusable, but they are cheap, so a new set would probably fix the issue
what carbs are you using now? the ones from the kz? if so did you change the jetting? the gpz will need more gas IMO. did you try to tighten the speedo cable?:unsure:
  • apeman
  • apeman's Avatar
Re: KZ750 vs GPZ750
01 May 2007 20:44
#136307
I am betting the "vibration" is a bad speedo cable. Swap it out, lube the new one, then try it.
  • Leaderone
  • Leaderone's Avatar
Re: KZ750 vs GPZ750
01 May 2007 20:56
#136314
if you dont mind me asking, how much did all this work cost you?
