oil leak
  • BSKZ650
  • BSKZ650's Avatar Topic Author
oil leak
04 Feb 2007 11:01
#110148
on my 77 LTD 1000 I have a small oil leak on the left side of the head, there are two soft plugs under the cam half moons,
there are two on the right side but they dont leak,
Any idea on how to seal these off, I am not sure silicone will do it,
one more note, I see the oil trail after it has been sitting,
77 ltd1000, current rider
76 kz900, just waiting
  • wireman
  • wireman's Avatar
Re: oil leak
04 Feb 2007 11:50
#110154
common leak spot try a new valve cover gasket and pull the rubber plugs out and clean them at same time and reinstall them with just a little 3 bond on them;)
Re: oil leak
04 Feb 2007 11:55
#110156
Perhaps oil in the top end puddles toward the left side when leaning on the kick stand. Probably an easy fix. May want to check/adjust valve clearances while cam cover is off, also use new cam cover gasket, maybe new cam end plugs too (huge variety available in mutiple colors if desired). If tach drive is oozing, good time to change the tach drive seal and o-ring also.
Believe www.Z1Enterprises.com has everything needed for any or all of these.
Lots of helpful info available by typing cam plug leak in the search forum box. Here's one of the threads --
kzrider.com/component/option,com_joomlab...9/view,flat/catid,2/
If new plugs are needed -- www.z1enterprises.com/detail.aspx?ID=104
Good Luck! :)
Post edited by: Patton, at: 2007/02/04 14:58
  • BSKZ650
Re: oil leak
04 Feb 2007 12:33
#110163
its not leaking at the valve cover or the half moon caps, its a soft plug that is down at the area of the head stud nut
  • wireman
  • wireman's Avatar
Re: oil leak
04 Feb 2007 12:45
#110165
pictures?;)
Re: oil leak
04 Feb 2007 12:51
#110166
Remain uncertain about which part is involved. :unsure:
Does it show in this diagram?
  • Skyman
  • Skyman's Avatar
Re: oil leak
04 Feb 2007 13:00
#110168
Slightly OT, but while reading this, it made me think, what is the purpose of the half-moon rubber cam plugs? Do they serve any purpose other than to leak? Why not just bring the head rim up to meet the cover flush?
West Linn, OR
  • BSKZ650
Re: oil leak
04 Feb 2007 13:04
#110170
the half moon caps, are needed so that the cam bores can be line bored
  • BSKZ650
Re: oil leak
04 Feb 2007 13:07
#110171
they are not shown on the break down, I will have to wait until the monday to get a camera to take a pic
  • Nevco48
  • Nevco48's Avatar
Re: oil leak
04 Feb 2007 13:08
#110172
I'm thinking it has to do with how the head was milled, but then again, I'm usually wrong. OK, I'll go back to chitchat where I belong.:pinch:
  • wiredgeorge
  • wiredgeorge's Avatar
Re: oil leak
04 Feb 2007 14:22
#110183
Have we determined what type bike is being referred to? There are no soft rubber plugs on a 903cc/1015cc or J motor below the cam end plugs. The cam end plugs are there so oil doesn't drool out the cylinder head. The half moon cut offs are there because the head was originally cast with the cam caps as part of the casting. A drill bit was pushed through that hole from the side (the line boring mentioned) to make the holes for the bearing surfaces the casting is cut and the cam caps result... I think that is the way it is done.
  • BSKZ650
Re: oil leak
04 Feb 2007 19:58
#110269
the soft plugs look like a lead plug, probably not lead, they are some type of oil gally plug ,I will get some pics, monday.
