Z1KZP swing arm swap 05 Sep 2020 22:25 #834461
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2635
This just might work. B)
Z1
98 KZP
Last edit: by SWest. Reason: Add pics
Z1KZP swing arm swap 07 Sep 2020 13:35 #834554
  • SWest
  • 10 22 2014
Moved this from my Bossie the Kaw thread. More to come. B)
Z1KZP swing arm swap 09 Sep 2020 15:34 #834678
  • SWest
  • 10 22 2014
No eBay APP ID and/or Cert ID defined in Kunena configurationLooks like my swing arm will be here Friday. I can work around the chain and brake stay issues but I think shock placement might be a show stopper. :unsure:
Been comparing the different ones through the production lines.
1978
Looks like the Z1
1998 KZP
2002-05
Looks hammered to me
Z1KZP swing arm swap 12 Sep 2020 11:44 #834863
  • SWest
  • 10 22 2014
It came. Looks good. He told me it was 41.75mm round not 47. Turns out it's the same as the Z1's. It is a little longer but not as long as the one I modded up. I'll dig it out to compare. It should work great. B)
www.kzrider.com/forum/5-chassis/600555-s...d-z1-zzr1200?start=0
Z1KZP swing arm swap 16 Sep 2020 21:50 #835199
  • SWest
  • 10 22 2014
Internet has been down since 8 AM Sunday. Got some catching up to do. :whistle:
Z1KZP swing arm swap 17 Sep 2020 09:13 #835224
  • SWest
  • 10 22 2014
Groping my way though this thing. :dry:
Z1KZP swing arm swap 17 Sep 2020 09:15 #835225
  • SWest
  • 10 22 2014
Welder is working better. :)
Z1KZP swing arm swap 19 Sep 2020 06:29 #835343
  • SWest
  • 10 22 2014
Diving into it. B)
Z1KZP swing arm swap 19 Sep 2020 13:51 #835362
  • SWest
  • 10 22 2014
A little more to it than I thought. :unsure:
Z1KZP swing arm swap 19 Sep 2020 14:35 #835366
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1866
Your correct on the frame tubes sounding thicker. According to a book I just received and digging into, the tube wall thickness of your Z1B is 1.8mm and the next gen A4 was built out of 2.3mm wall tubing. Not sure if they were increased again after the 1977 Kz900 A5. Id assume the swing arm was increased in a similar way.
Last edit: by Mikaw.
Z1KZP swing arm swap 19 Sep 2020 18:38 #835385
  • SWest
  • 10 22 2014
Slow going but getting there.
Z1KZP swing arm swap 20 Sep 2020 18:11 #835438
  • SWest
  • 10 22 2014
Final install tomorrow.
