Look What I Got!! (1978 KZ650B(?))
  • DSummerlin
  • DSummerlin's Avatar Topic Author
21 Mar 2018 15:26
#780578
Got this off of craigslist. Shows a bit over 8K on the odometer. PO told me it would need to have the Dyna S that he had installed replaced.
I got a spark w a jumper box, so I primed the carbs and it fired up on all four.
I could ride it but it wasn't charging. Big thanks to Zuki Dave for giving me a spare 3 phase charging system he had in a box under his bench. Lots of cleaned connections, new wires, and a new spare reg/rectifier I had from my KZ1000 follies and it seems to be charging.
Runs great, airbox is intact, I replaced the carb boots (manifolds/holders) and spark plugs (one was hand tight w visible blow by!)
Thing is pretty clean and complete. Has OG seat that could use reupholster as well as the cafe seat that's on it. The tail was butchered a little to make that seat fit. I've mostly just cleaned it. I did wet sand the bodywork a little.
Roast away, I guess.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Look What I Got!! (1978 KZ650B(?))
21 Mar 2018 15:33
#780580
This is a good catch with 8K on the odometer, thumbs up
The bike is looking real good.
The following user(s) said Thank You: DSummerlin
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
21 Mar 2018 17:42
#780586
Nice find indeed!
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
26 Mar 2018 13:31 - 26 Mar 2018 13:34
#780840
Nice! What's the build date? Still got the orig seat, right? Say "Kawasaki" on the back of the material? 8k... sweeeet!
I think it's a B2a. Plastic chain guard, not on the early 78' B2. Those were still metal, IIRC.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 26 Mar 2018 13:34 by !Seymore.
  • DSummerlin
27 Mar 2018 05:44
#780877
Rode it this weekend with a little group of old bikes. We put on maybe 150 miles, and the 650 was a little champ. Got over 40 mpg; bike got to sing a little.
It did cime with another seat, though that may have been recovered b/c it has no "Kawasaki" logo. I appreciate the info. Is it little stuff like plastic chain guards/ mags vs spokes and # of brakes that are the biggest differences?
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
  • DSummerlin
27 Mar 2018 06:36
#780881
Also, that's a weird Vetter headlight unit. I'd like to go back to a KZ bucket/etc. Would chrome or black bucket be more "correct?" I'm leaning towards chrome, but I mainly want to get the wires in a place up there and just run this thing as a clean little survivor. I don't really want or need to do a resto, and I certainly don't want to cut it up or try to turn it in to something it's not. I'm looking for reliability and utility.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
  • DoctoRot
  • DoctoRot's Avatar
27 Mar 2018 08:42
#780888
a black bucket would have been stock on the B2. If it has a Vetter headlight it probably was a factory windjammer bike and has a bunch of extra wiring in the bucket for the running lights on the fairing.
  • DSummerlin
27 Mar 2018 09:15
#780889
Yeah I'm almost certain I saw this same bike a couple of years back further away on Craigslist with a fairing. It does have some funky wiring up front and the aftermarket signals might have added to some of that. Everything works, sanitary or not, and I only hope to clean stuff like that up as I go.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
  • ajsfirehawk
  • ajsfirehawk's Avatar
27 Mar 2018 10:02
#780893
Really nice find. Those are wonderful motorcycles.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
28 Mar 2018 14:23
#780940
DSummerlin wrote: Rode it this weekend with a little group of old bikes. We put on maybe 150 miles, and the 650 was a little champ. Got over 40 mpg; bike got to sing a little.
Nice... well, when you get her opened up... say over 7k, for a long stretch... she should "sing" for ya. Listen for the notes, you'll hear them under your helmet.
So, again... what's the build date? Should be on the neck sticker.
C.
  • Nessism
  • Nessism's Avatar
  • Away
28 Mar 2018 17:02
#780943
Great looking bike! You done good!
Be sure to go through the manual and catch up all the maintenance. Valve adjustment is almost always overlooked by PO and failing to adjust the valves can damage the engine so...
The following user(s) said Thank You: KZB2 650, DSummerlin
  • DSummerlin
30 Mar 2018 21:49 - 30 Mar 2018 21:49
#781057
I'll look for build date. Promise.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
Last edit: 30 Mar 2018 21:49 by DSummerlin.
