Look What I Got!! (1978 KZ650B(?))
- KZB2 650
Re: Look What I Got!! (1978 KZ650B(?))
01 Apr 2018 11:16
I still get a thrill every time I visit the shed and its been 38 years...... great deal and have fun.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- DSummerlin
01 Apr 2018 14:28
Here's the vin. Does that help figure out the date of manufacture?
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
82 KZ1000 LTD
99 ZRX 1100
01 Apr 2018 15:35
Based on the VIN your bike was probably built in 1978 but it is very likely a 1979 KZ650-B3 model. See
models.kz650.info/index.htm
Does the generator cover and points cover have the name Kawasaki in upper and lower case letters or all upper case letters? What is the engine serial number (can be found next to oil filler hole). Ed
1978 generator cover
1979 generator cover
- DSummerlin
01 Apr 2018 15:38 - 01 Apr 2018 16:46
Mine is all caps.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
82 KZ1000 LTD
99 ZRX 1100
Last edit: 01 Apr 2018 16:46 by DSummerlin.
01 Apr 2018 19:08
Since yours is all caps it probably is a 1978 engine. Check the engine number against the list in the link I sent to confirm. Ed
- DSummerlin
02 Apr 2018 06:20
Sure. It also had a single phase charging system which as I understand it was 78 only. Any other major differences between 78 and 79, or ?
If it turns out to be a 79, I don't think I'd like it any less or stop calling it a 78, because I'm pretty sure that's what it is...
"built in 1978 but it is very likely a 1979 KZ650-B3 model...." is this common or something? So, if it's a 78 (will confirm after work) what would the official designation be? And are these just calendar date related specifics, or were there notable changes? Thanks for sharing your knowledge.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
82 KZ1000 LTD
99 ZRX 1100
- KZB2 650
02 Apr 2018 08:14
Thinking its a 78 like mine. Your showing the points cover while Ed means to look on the other side at the alt cover for caps......... thinking the 79 model would have the emissions air vent set up on the valve cover too while the 78 wouldn't (right Ed) ??? The side covers show a 78 model too as the emblems are recessed and the 79 model is flat where they attach........ the KZ is slightly smaller on the 78 too while the 79 is closer to being the same size as the 650 numbers. Then there is the color red where its avaliable in 78 but not 79 although it could be re painted (but probably not).
1978 KZ650 b-2
- DSummerlin
02 Apr 2018 12:55 - 02 Apr 2018 13:00
D'oh!!! His pic is clearly of the alt cover. Man, my old brain. Alternator cover is all caps too. Paint really seems original besides my polishing, etc., no emissions valve cover... So, B2?
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
82 KZ1000 LTD
99 ZRX 1100
Last edit: 02 Apr 2018 13:00 by DSummerlin.
- rstnick
02 Apr 2018 16:59 - 02 Apr 2018 17:00
Plastic chain guard was standard for all B & C models.
This site has a good listing of the various 650 models, listing changes from year to year:
www.jarlef.no/Kawasaki/Series/Z/650/z650.htm
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 02 Apr 2018 17:00 by rstnick.
- !Seymore
- Ride on...
03 Apr 2018 14:03DSummerlin wrote: Here's the vin. Does that help figure out the date of manufacture?
No. On the neck sticker (granted it's all still there) will be all the info needed. Hard to take PICs, sometimes, but this is always the first place I look.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- DSummerlin
04 Apr 2018 14:19
Here y'all go.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
82 KZ1000 LTD
99 ZRX 1100
The following user(s) said Thank You: !Seymore
- !Seymore
- Ride on...
15 Apr 2018 21:17
Looks like it's late in 78'? I can make out a 1, I think, before the year... (MM-YY) 1x-78 ? Oct-Dec? That would make is a 79'. It would have been sold as a 78' if it was 01-78. The next years bikes were started 2-3 months into the prior year.
Either way, 78' or 79'... ride it like you stole it!!!
Took another look at your PICs... nice! You got a clean classic, rare these days.
C.
