Can I simply RATTLE CAN my engine black?
  • 650Dude
  • 650Dude's Avatar Topic Author
  • Banned
  • Banned
24 Feb 2018 12:42 - 24 Feb 2018 12:43
#779281
Im so sick of trying to polish these stupid fins. I DESPERATELY want to paint this engine fins black. I probably wont paint the engine cam covers black but can I just do this with a rattle can using high temp paint?
Here is my bike
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
Last edit: 24 Feb 2018 12:43 by 650Dude.
  • zed1015
  • zed1015's Avatar
Re: Can I simply RATTLE CAN my engine black?
24 Feb 2018 12:57
#779286
The correct paint is Wurth satin or Simoniz/Sperex tough satin which looks very close to the original kawasaki engine black finish once cured.
Both are very similar to the old formula PJ1 .
You really need to strip and blast the motor to get a good key for the best job.
If you try to paint it in situ it will end up looking worse and the paint will soon flake.
  • 650Dude
  • Banned
  • Banned
24 Feb 2018 13:12 - 24 Feb 2018 13:14
#779289
zed1015 wrote: The correct paint is Wurth satin or Simoniz/Sperex tough satin which looks very close to the original kawasaki engine black finish once cured.
Thanks for this. But I dont need it stock color, I just want it black. Im SICK of cleaning the oxidation off of those damn fins. I will rattle can it with Rustoleum High Temp paint while its on the bike.
Last edit: 24 Feb 2018 13:14 by 650Dude.
  • DoctoRot
  • DoctoRot's Avatar
24 Feb 2018 15:14
#779293
I have had good luck painting assembled engines, by cleaning them REALLY well, then using metal etch to prep them before paint.
  • 650Dude
  • Banned
  • Banned
24 Feb 2018 15:25
#779294
DoctoRot wrote: I have had good luck painting assembled engines, by cleaning them REALLY well, then using metal etch to prep them before paint.
Thanks for this. Can you recommend a good spray paint....
  • z1kzonly
  • z1kzonly's Avatar
24 Feb 2018 15:28
#779296
DO NOT USE RUSTOLEUM! Clean as best you can, scuff with Scotch-brite pads
Dupli -Color engine enamel or PJ1. I have been waiting to test KRYLON high heat also, I have used there aluminum/silver before. Never used their black.
Believe this or not, 25-30 years ago I painted Kaw engines with black Lacquer aerosol cans. It worked great. VHT never had gloss black, only flat. So I always painted my stuff gloss black
  • Kollector
  • Kollector's Avatar
24 Feb 2018 15:38
#779297
Go to your local auto parts store and look at Duplicolor high temp engine enamel, gloss black and gloss clearcoat. This stuff sticks like epoxy. I've used it successfully on engines and bodywork. I'm not kidding, this stuff is amazing.
'83 KZ750 Spectre, '01 ZRX1200R, '03 ZZR1200, '84 GPZ900R, 7 Hondas, 1 Yamaha
  • 650Dude
  • Banned
  • Banned
24 Feb 2018 15:54
#779298
z1kzonly wrote: DO NOT USE RUSTOLEUM! Clean as best you can, scuff with Scotch-brite pads
Yeah by buddy told me a little earlier in the day that PJ1 was best and that Rustoleum would be a disaster. Im thinking of doing the WHOLE thing black now. Should I scuff the chrome with scotchbrite on the clutch cover etc? I saw this photo and it looks awesome.
  • 650Dude
  • Banned
  • Banned
24 Feb 2018 16:04
#779299
Kollector wrote: Go to your local auto parts store and look at Duplicolor high temp engine enamel, gloss black and gloss clearcoat. This stuff sticks like epoxy. I've used it successfully on engines and bodywork. I'm not kidding, this stuff is amazing.
Thanks! The delivery time for the PJ1 is quite a while so Im going to take our suggestion and get the Duplicolor! Do I really need clearcoat on top of the paint? I dont want my aircooled engine to run hotter because its smothered.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Feb 2018 16:11
#779300
Have you a SS wire brush wheel? Once done you can't go back.
  • 650Dude
  • Banned
  • Banned
24 Feb 2018 16:13
#779301
SWest wrote: Have you a SS wire brush wheel? Once done you can't go back.
Yes Ive got every tool under the sun, but I dont want debris on the bike before i paint it. I used steel wool once and there were shavings everywhere. I think Im going to use scotchbrite.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
24 Feb 2018 16:36
#779302
I used gloss black and prefer the look over flat.
Prep is critical for a good job. Better with motor out of the frame but it is up to you
Along with wire wheel / scotchbrite / and picks for the nooks and crannys I would power wash and blow dry with a air compressor
All Black is nice , but I prefer some contrast on my motors.
Once painted and cured ( Run it and drive it for paint to setup.
I like taking a metal file and 2x4 wrapped in emery cloth to clean off the fin edges on the cylinder head
See attached pictures of my bike and Doctor rots motor
