Brake lines
- Paulharshaw
Brake lines
03 Nov 2016 14:53
Trying to find a steel braided upper brake line for a kz900 ltd. I've got galfer on all the rest but doesn't seem available for the upper. Any suggestions
- DoctoRot
Re: Brake lines
03 Nov 2016 20:30 - 03 Nov 2016 20:30
I buy my brake lines and banjos from Z1 enterprises. you should be able to put together whatever you need there.
www.z1enterprises.com/store/category/kaw...l-brake-tire/ss-hose
Last edit: 03 Nov 2016 20:30 by DoctoRot.
The following user(s) said Thank You: Paulharshaw
- Paulharshaw
Re: Brake lines
04 Nov 2016 10:41
Quite a selection. I tossed out the old upper brake line any idea how long a line I need and which banjo's it requires
- DoctoRot
Re: Brake lines
04 Nov 2016 10:55
I'm not sure what length, it depends what handlebars you are running. its pretty easy to measure with a bit of hose or wire, then just subtract 3" for the banjo fittings. IIRC you need a 30 degree banjo for the master cylinder and a straight one at the splitter. but i would check against your bike to be sure.
- barney
Re: Brake lines
04 Nov 2016 11:09
I do my own .I buy all the Earls Performance Plumbing parts from Summit racing. Ive had no problem with them. Make them any length you choose
Barney
Barney
The following user(s) said Thank You: Nessism, Paulharshaw
- KZB2 650
Re: Brake lines
04 Nov 2016 12:07
Changed the fluid more than a few times over the last 36 years but never the lines .... and the manual says every 4 years.... talk about pushing your luck.... will very soon though (planning next year) with either Earls or Z1's.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- car5car
- Banned
Re: Brake lines
21 Nov 2016 00:47Sometimes old rubber brake hoses start working like valves:KZB2 650 wrote: Changed the fluid more than a few times over the last 36 years but never the lines .... and the manual says every 4 years.... talk about pushing your luck.... will very soon though (planning next year) with either Earls or Z1's.
fluid goes to calipers but not back.
96 Yamaha Royal Star
82 Yamaha Virago 920
Re: Brake lines
21 Nov 2016 05:10 - 21 Nov 2016 05:13
This is what the brake lines on my 750E looked like on the inside after 35 years...
You can "flush" the fluid all day long and you will never get this grung out.
Oh, and I use Earl's parts and make all my own lines too. I've got a photo tutorial describing the process if anyone wants to give it a go.
Last edit: 21 Nov 2016 05:13 by Nessism.
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
Re: Brake lines
21 Nov 2016 19:58
How would i get to it?
Nessism wrote: This is what the brake lines on my 750E looked like on the inside after 35 years...
- RonKZ650
Re: Brake lines
21 Nov 2016 20:40
All 7 of my old Kawasakis still have original brake lines, even the 1974. Being 42yrs old the lines are really dangerous I suspose in theory but they work just fine.I did replace the lines once on the KZ1000MKII with braided stainless and they worked OK, just like old rubber lines, then later just preferred going back original. Be aware if you buy braided lines, the way they measure is end to end, not center of the banjo to center. Measure the whole length stretched out straight. No advantage to them or new lines in my opinion and experience.
Re: Brake lines
21 Nov 2016 20:44
Mine work fine as well.
Re: Brake lines
22 Nov 2016 05:46swest wrote: Mine work fine as well.
When you flush the fluid how long does it stay clear? When there is scale on the inside of the line the clear fluid will turn browish after a few weeks as the crud sticking to the inside of the lines leaches out and contaminates the new fluid.
