83 kz550a case guard don't fit.
- Kirkpatrick
12 Apr 2016 19:47
Ok, I have searched ebay, etc. for case guards for my 83 kz550a model and found a lot that are universal for 81-83. Found a set on
ebay
for an 82 kz550 from KG Engineering. As I suspected, after they arrived, the bolt patterns do not match up. It is a 3 point mount where the middle bolt hole has not frame bolt to match up to. So my question is that I love the way they look but is there a company out there that actually makes them for the 83 kz550a?
1983 Kawasaki KZ550
1983 Suzuki GS1100ED
1982 Suzuki SZ1000 (Katana)
1997 Honda CR500
1997 Honda CR500
Re: 83 kz550a case guard don't fit.
12 Apr 2016 19:58 - 12 Apr 2016 19:59
The eBay listing selling those case guards didn't make any sense. The title shows KZ550 but the text shows KZ1000. Clearly there's a major difference between the two bikes. Fortunately, the seller does accept returns. Ed
Last edit: 12 Apr 2016 19:59 by 650ed.
12 Apr 2016 20:01
If he does or not, NOT AS DESCRIBED will make him take them back with shipping.
- loudhvx
13 Apr 2016 09:06 - 13 Apr 2016 09:13
The 550 motors all have the same case bolt pattern, so it should line up to any KZ550 if it uses the engine mounting bolts. Some of the later ones use rubber-cushion mounts, but the bolt alignment is the same. Even the Zx550 uses Kz motor cases.
As Ed and Steve suggest, you should return them.
And, there are definitely KZ550/ZX550 case guards available. I've seen many, but sorry I don't have any brand-name or model numbers.
Be aware, some use two mounting points and some use three.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 13 Apr 2016 09:13 by loudhvx.
- Kirkpatrick
16 May 2016 16:05
I found some that fit but need help with hardware. Posted a question here
BOLT LINK
. Thanks, Brendan
1983 Kawasaki KZ550
1997 Honda CR500
1997 Honda CR500
