Help Needed with Case Guard Bolts
- Kirkpatrick
16 May 2016 15:36 - 16 May 2016 16:03
Just picked up a set of case guards for my 83 KZ550A4 but they did not come with the hardware. I found the stock bolts below from a parts diagram and was wondering if anyone here knew what the size increase is needed on the bolts because of the case guard bracket and what the actual pitch of the bolt is. I know they are metric (ie 8x60 = M8x60mm). Any help is appreciated.
(2) 92001 - BOLT, HEX HEAD, 10X84 (Left Lower & Right Lower)
(1) 92001B - BOLT, FLANGED, 8X60 (Right upper - 1 of 3 bolts)
(1) 92001C - BOLT, FLANGED, 8X70 (Right upper - 1 of 3 bolts)
(1) 92001D - BOLT, FLANGED, 10X60 (Right upper - 1 of 3 bolts)
(1) 92001E - BOLT, FLANGED, 10X70 (Left upper)
1983 Kawasaki KZ550
1983 Suzuki GS1100ED
1982 Suzuki SZ1000 (Katana)
1997 Honda CR500
1997 Honda CR500
Last edit: 16 May 2016 16:03 by Kirkpatrick.
- Kirkpatrick
Re: Help Needed with Case Guard Bolts
16 May 2016 20:25
Just trying to figure out it if I simply go 10mm longer on a set of replacement bolts, will that work or will they be too long then. The brackets on the case guards are about 1/4" with the steel and powder-coat. Don't know how much extra thread room there is in the cases but could always use a washer. Just a little difficult to find the 8mmx65 vs the even number 8mmx70.
1983 Kawasaki KZ550
1997 Honda CR500
1997 Honda CR500
- rrsmsw9999
16 May 2016 20:29
Boltdepot.com
hands down best price and selection.
R
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
The following user(s) said Thank You: Kirkpatrick
- Kirkpatrick
16 May 2016 20:33
One step ahead of you brother. Already have the order saved in my cart. Just waiting for the pros on the website here to respond.
Brendan
Brendan
1983 Kawasaki KZ550
1997 Honda CR500
1997 Honda CR500
17 May 2016 03:50
Something to be aware of is the bolt head size. The local fastener place nearby had M10 bolts but the bolt heads were too big to fit into the engine recesses. I ended up getting 3/8" bolts instead. doh.
- Kirkpatrick
29 May 2016 16:06
On the right side, do I need to keep the triangle engine/frame mount? The engine guard I have already has one as part of its design?
1983 Kawasaki KZ550
1997 Honda CR500
1997 Honda CR500
- Kirkpatrick
06 Jun 2016 22:19 - 06 Jun 2016 22:20Had to use two 3/8 bolts but it looks awesome!!!martin_csr wrote: Something to be aware of is the bolt head size. The local fastener place nearby had M10 bolts but the bolt heads were too big to fit into the engine recesses. I ended up getting 3/8" bolts instead. doh.
1983 Kawasaki KZ550
1997 Honda CR500
1997 Honda CR500
Last edit: 06 Jun 2016 22:20 by Kirkpatrick.
07 Jun 2016 07:37
Nice machine.
07 Jun 2016 08:10
Nice bike! I've always liked that paint scheme. Ed
