Who has KZ1000E (shaft) service manual?
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
03 Mar 2016 03:34 - 03 Mar 2016 03:37
#713568
It probably doesn't exist. Local Kawasaki dealer doesn't have it for their mechanics!
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 03 Mar 2016 03:37 by car5car.
Re: Who has KZ1000E (shaft) service manual?
03 Mar 2016 03:40
#713569
No eBay APP ID and/or Cert ID defined in Kunena configurationIt does exist. There's a manual or supplement for every model. Here's one for the KZ1000 Shaft. Ed
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
03 Mar 2016 03:52
#713571
Yep...I can verify its existence...I own one. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • car5car
  • Banned
  • Banned
03 Mar 2016 04:00 - 03 Mar 2016 16:34
#713572
Mcdroid wrote: Yep...I can verify its existence...I own one. :)
Please let me know clutch spring length specs. If I have "tired" springs, most likely you do too, unless you replaced them. 15 min replacement time! 8 bolts cover, 6 bolts cluth push plate
I measured 32mm. All friction disks are OK, so springs are most likely reason for minor slipping.
I ordered EBC spring from ebay for $100 shipped.
Last edit: 03 Mar 2016 16:34 by car5car.
  • Rockranch
  • Rockranch's Avatar
03 Mar 2016 04:39
#713574
car5car wrote: It probably doesn't exist. Local Kawasaki dealer doesn't have it for their mechanics!
I've seen them in local libraries too. kz900.com/books/index.html#kz1000 ..............................Mike
Vroom-vroom!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
  • GPzMOD750
  • GPzMOD750's Avatar
03 Mar 2016 04:48 - 03 Mar 2016 04:49
#713575
I found a place called repairmanuals.com that has scanned and plastic comb bound copies. I went and found me a 1" binder, some plastic sheet protectors and cut the binding off and stuffed every page into it's own protector. This way I can pull out only the pages I need, handle them with grimy hands and put them back when I'm done.
Pics of my KZ750 manual
Last edit: 03 Mar 2016 04:49 by GPzMOD750.
  • martin_csr
  • martin_csr's Avatar
03 Mar 2016 04:52 - 03 Mar 2016 04:57
#713576
There's a 1000 ST manual listed at repairmanual.com. it's fairly cheap too.
Last edit: 03 Mar 2016 04:57 by martin_csr.
  • GPzMOD750
03 Mar 2016 04:58
#713577
martin_csr wrote: There's a 1000 ST manual listed at repairmanual.com. it's fairly cheap too.
I have it. Just don't have pics of it.
  • Rockranch
03 Mar 2016 05:14
#713580
1 modified
  • martin_csr
03 Mar 2016 05:28 - 04 Mar 2016 04:42
#713582
By GPzMOD750: I have it. Just don't have pics of it.
How does that help the op? Are you going to sell it to him or what?
Last edit: 04 Mar 2016 04:42 by martin_csr.
  • GPzMOD750
03 Mar 2016 05:40 - 03 Mar 2016 05:42
#713584
Clarification that i have both the 750 & 1000 manuals from the same source, given the same treatment.
Not for sale. I'm not done with mine yet.
Last edit: 03 Mar 2016 05:42 by GPzMOD750.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
03 Mar 2016 06:32
#713594
Please let me know clutch spring length specs. If I have "tired" springs, most likely you do to, unless you replaced them. 15 min replacement time! 8 bolts cover, 6 bolts cluth push plate
Kawasaki doesn't evaluate clutch springs on your model by the length of the spring, but rather, by spring tension...standard being 19.1-22.5 kg. Replace at 17.5 kg. Of course, they use a special tool to measure tension...which few of us have. You are probably safe by replacing. I did note that they say spring length for a stock spring is 22.1 mm. You probably already have HD springs.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
