What Tires do you Run
- missionkz
Re: What Tires do you Run
10 Sep 2015 14:11
I was wondering if it was a tube friction failure issue or carcass heating from tube squirm friction issue... etc
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
10 Sep 2015 14:21 - 10 Sep 2015 14:24
That may be the source of extra heat. Here's a link that states "Also, when using a tube in a tubeless tire you should downgrade the speed rating by one to compensate for the increased heat due to friction between the tube and the tire carcass."
www.motorcycleclassics.com/tech-corner/t...ms-zm0z13ndzbea.aspx
Here's another that mentions heat as the reason for reducing the speed rating:
bmwmotorcycletech.info/section5.htm
Last edit: 10 Sep 2015 14:24 by 650ed.
- spdygon
11 Sep 2015 03:26
If u hit 140 on a KZ ...u actually doing around 125.
U hit 160 you are around 140mph
No need for V Rated Tiires unless u doing some kind of racing.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- Zephyrrider
11 Sep 2015 12:42
Used Pirelli Dragons on the YZF 750 i had - dont know if they even make them now- brilliant tyres but spent $2000 in 14 months on them so got rid of that bike - far too expensive to run.
Mick
1994 ZR750 Zephyr C4.
11 Sep 2015 13:15Zephyrrider wrote: Used Pirelli Dragons on the YZF 750 i had - dont know if they even make them now- brilliant tyres but spent $2000 in 14 months on them so got rid of that bike - far too expensive to run.
I know the feeling! Way back in the late '70's I was running Michelin tires with the PZ2 compound. I could put 1,000 miles on the rear; 2,000 miles on the front before they were shot. Back then I was running 6,000 miles a year, and at $100 per tire I was spending $900 per year on tires. After 2 years I came to my senses and stopped running the racing compound on the street, Too much money, but man, those tires really did stick to the road like glue! Ed
- Zephyrrider
14 Sep 2015 00:05
Thats crazy low mileage Ed - they would have been incredible tyres alright - i did considerably better out of the Dragons but still only a few 1000.Other things like an air filter being $120 and all the crap i had to take off to get at anything kinda killed the sports bike enthusiasm - oh and it was too uncomfortable as well- went ok though - had it up to 255 km/h but it wasnt a Kawasaki
Mick
- DoctoRot
14 Sep 2015 08:18 - 14 Sep 2015 08:19Spencer440 wrote: I also run shinko 712's... I like the price, and they grip well in dry conditions, but they wear very quickly (usually 2,500 miles or less on the rear, and 7,000 or less on the front.) I plan on trying out the Avon AM26 tires for my next set.
are you doing burnouts everywhere you go? I have gone through several sets of 712's and usually get about 8k on the rear, 12k on the front. although the last rear tire I rode down to the steel.
Last edit: 14 Sep 2015 08:19 by DoctoRot.
- dom2570
Re: Re:What Tires do you Run
14 Sep 2015 10:44No joke, I put 6000 at least on mine and they still look new...but I ride like an old man. LolDoctoRot wrote:Spencer440 wrote: I also run shinko 712's... I like the price, and they grip well in dry conditions, but they wear very quickly (usually 2,500 miles or less on the rear, and 7,000 or less on the front.) I plan on trying out the Avon AM26 tires for my next set.
Whip it like a mule!
- Spencer440
14 Sep 2015 11:49 - 14 Sep 2015 11:49DoctoRot wrote:Spencer440 wrote: I also run shinko 712's... I like the price, and they grip well in dry conditions, but they wear very quickly (usually 2,500 miles or less on the rear, and 7,000 or less on the front.) I plan on trying out the Avon AM26 tires for my next set.
5k launches, small wheelies, downshifting, and lots of twisty roads and your tires wear down pretty quickly. I'm also riding in a lot of stop n go traffic (inner city in Memphis), and I tend to like to accelerate quickly (which leads to breaking more quickly), so my tires wear out pretty quick. Even with good tires, I usually last less than 5,000 miles on the rear, and usually 10,000+ on the front, with a good tire, like the dunlop gt501.
Also, I usually change tires, as soon as my tread is down to 1/16" or less, on atleast 60% of the tire. So, I may still have a few hundred miles of life, but with the way I ride, I change tires frequently.
1980 KZ440-B
1979 Kawasaki KZ650-C3
Last edit: 14 Sep 2015 11:49 by Spencer440.
- Zephyrrider
14 Sep 2015 13:43
Never seen the sense in burnouts - what does it achieve really. Even watching someone gets old very quickly. Let them twisties wear em down i reckon. No city stuff - takes me a minute to get out on the highway . Never had 1 down to steel. Bit like my oil changes - probably change before i need to but makes me very confident
Mick
- missionkz
14 Sep 2015 14:26
I have about 1100 miles on my new Shinko 712 tires.... so far, my little Auto Zone tire depth gauge, stuck as close to dead center as I can on the rear tire says ...I have dropped about a 1/32" from when new.... that sounds like at least a 7000-8000 mile tire to me if I don't hot dog it too much. And out here in the Denver area... it is all straight line driving but in mountains... there are no straight roads and a blast to cruise through about 10mph-15mph over the flat lander's, sissy speeds for tourists.
Bruce
1977 KZ1000A1
1977 KZ1000A1
- jackleberry
14 Sep 2015 14:54 - 14 Sep 2015 14:57
I'm also running Shinkos. F 230 in front and 712 in the rear. Big improvement over Dunlop 404s (and runflats, obviously). I find them to be a very reasonable cost/longevity/performance compromise.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
Last edit: 14 Sep 2015 14:57 by jackleberry.
