Wow...Speedo way off
  • spdygon
  • spdygon's Avatar Topic Author
16 Aug 2015 13:53
#685980
So I always wonder why car be passing me when I'm already doing 75mph on the highway.
Saturday for the first time a used a GPS on my 78 z1r.
At 55 ..gps said 46mph
At 70..gps said 63mph
And at 80..gps said 73
So I have to drive at 85 on my speedo to actually be doing 76.
Anyone else have found this to be?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Wow...Speedo way off
16 Aug 2015 14:13
#685983
What size tire do you have up front?
  • spdygon
16 Aug 2015 20:28
#686034
The original 18" for the z1r. What sucks too is that the GPS said 54 miles to distination and the bike recorded 64 miles.
1974 Z1 900 project
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Aug 2015 21:15
#686036
I'm talking about the size of the tire not the rim. I thought the front was 19" like most of them at that time. Ether way it could be a larger tire but now a smaller rim?
  • spdygon
17 Aug 2015 13:03
#686103
All equipment is original.
1974 Z1 900 project
17 Aug 2015 13:21
#686104
spdygon wrote: The original 18" for the z1r. What sucks too is that the GPS said 54 miles to distination and the bike recorded 64 miles.
That's interesting. I can understand the speedometer being inaccurate since it is not directly driven from the cable and sending unit, but I thought the odometer had gearing that is directly connected to the cable coming from the sending unit. Apparently I misunderstood the setup. :( Ed
17 Aug 2015 13:32 - 17 Aug 2015 13:34
#686106
spdygon wrote: So I always wonder why car be passing me when I'm already doing 75mph on the highway.
Motorcycle speedometers have for a long time been notoriously optimistic.
Am vaguely recalling that Triumph speedometers and maybe BMW speedometers more accurately reflect true road speeds, this being from the days of cable-driven speedometers.
Good Fortune! :)
Last edit: 17 Aug 2015 13:34 by Patton.
  • spdygon
17 Aug 2015 14:07 - 17 Aug 2015 14:08
#686112
So if I do the math on mileage.
64 divided by 54 = 1.19
11000 divided by 1.19 = 9244miles
So in reality my 78 z1r has 9244 miles
Not 11000. B)
1974 Z1 900 project
Last edit: 17 Aug 2015 14:08 by spdygon.
  • z1kzonly
  • z1kzonly's Avatar
17 Aug 2015 14:37
#686115
New that 35 years ago! Even before they wore out! Kaw speedos always sucked! at least 10 mph off.
So you get a friend or ? whomever in a decent car, drive with them on a highway, next to each other @55 , @65 etc. go by your rpm's.
At least that's what I did when I drove these cycles on the street 35 + years ago.
Pretty simple. For me anyway.
  • martin_csr
  • martin_csr's Avatar
17 Aug 2015 14:38 - 18 Aug 2015 05:45
#686116
If you know the circumference of the tire, some calculations can be done.
Also, the number of teeth on the speedo drive gear & on the pinion.
Or it would be handy to know what tire or the tire size. Or the radius of the front wheel/tire --- measure from garage floor to center of axle, with front tire properly aired up & resting on the garage floor; bike vertical; measurement within 1-2mm or 1/16".
Last edit: 18 Aug 2015 05:45 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
17 Aug 2015 16:00
#686122
Up to 10% error is pretty common for the speedometer, but like 650Ed, I've not heard of an odometer that far off.
  • RonKZ650
  • RonKZ650's Avatar
17 Aug 2015 21:03
#686170
I couldn't find my magazines with 1978 Z1R tests to see what they said of the speedo and gave up looking for now, but as mentioned a lot of them were optomistic, but the normal for kawasaki was about 4-5mph at 60mph. The odometer thing I don't get at all as your figure shows close to 20% off. I've never heard of this, and the normal was 3-4%. I rode my 79 KZ1000MKII 10,800 indicated miles on my last big trip, and actually was 10,300 or so according to my calculated miles using maps in the old days before GPS.
