Tell me what you guys think - 1976 kz900 ltd
  • JDRAKE4200
  • JDRAKE4200's Avatar Topic Author
Re: Tell me what you guys think - 1976 kz900 ltd
28 Jul 2015 21:01 - 28 Jul 2015 21:06
#683231
Swest.... Which one are you talking about? Is the one I bid on not for a 76?
Keep the shiny side up!!!!
1976 KZ900 LTD
2004 Sportster 1200 Custom
1981 KZ550 LTD
1994 GSXR 750
Last edit: 28 Jul 2015 21:06 by JDRAKE4200.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Jul 2015 21:02
#683232
I never put in the first bid. I wait until the last 20 minutes and put in my max bid.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
29 Jul 2015 04:32
#683247
Jason, if the bike has been running correctly I would not mess around with the float levels just yet. At least not until you can confirm if they are not set properly. It may be just debris from the tank which causing your problems. So before you fix the fuel leak you need to make sure you are not getting any debris from the fuel tank. Otherwise you will be chasing leaks continuously. Take the tank off, and let it drain into a clean container. See if there is any debris from what you drained. Go further and take off the petcock to clean out any debris it may have. Best to do this without shaking the tank from the point of taking it off so the debris doesn't get dispersed through out the tank. You may want to run some gas through the tank to see if you can get anymore out. When you reinstall the tank, add a clear inline fuel filter to prevent anything that's left from reaching your carbs. Next fix your leaky carb by taking the needle out and cleaning any debris. I had used new needles from my kits and it leaked. Ended up putting the old ones back but used some polishing compound to lap them with the seat a bit. Some use tooth paste. Have the make sure that you don't clog anything with the compound or paste. Leaks are a thing of the past for me. One more point, I always turn off my petcock when the engine is not running. Every single time. So I forgot to mention. When you have the tank off and sitting on a bench and has fuel in it. Confirm to make sure that the petcock is not leaking. All the fuel delivery system has to be clean and functioning properly to prevent float overflow.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jul 2015 05:17
#683255
JDRAKE4200 wrote: Swest.... Which one are you talking about? Is the one I bid on not for a 76?
It is for a 76. You may have jumped the gun by bidding too early. 5 days out is a long time.
  • JDRAKE4200
29 Jul 2015 06:16
#683267
No eBay APP ID and/or Cert ID defined in Kunena configurationIs this one for a 76 as well? Mislabeled?
Joe, carb on the outer most left has leaked since picked up. Tank off, cleaned. Fuel system is clean. Center left still leaking.
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
  • JDRAKE4200
29 Jul 2015 07:01 - 29 Jul 2015 07:25
#683280
Thanks guys
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
Last edit: 29 Jul 2015 07:25 by JDRAKE4200.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jul 2015 07:02
#683282
Looks like it will work. Pretty bad shape, no top and made for the air injection system. Hope you get the 76 one.
  • jeff80kz1000e2
  • jeff80kz1000e2's Avatar
29 Jul 2015 16:01
#683350
K.D. HART wrote:
JDRAKE4200 wrote: Ok…..so I just spoke with Jeff @ Z1 and he has advised me of the following:
The best replacement for my airbox, is the original.
The next best would be any KZ900 Box
The third best would be any box from 76-80 (non shaft drive)
And the last option should be the pods
The z1 airbox will work but modifications will need to be made
So, I have to ask, does anyone have an airbox or know anyone that has one from 76-80? Please let me know if so.
As for the tank, this just looks better (see attached) and you can go farther.....especially with my problem. I have TWS. (Throttle Wrist Syndrome).....the more gas the better
I don't know what mods to the Z1 airbox would have to be made? The Z1 airbox fit in my bike real nice with NO mods.
I used a 78 KZ1000 frame and use a Z1 airbox for my dogs sidecar bike. (The donor bike was a wrecked 1976 KZ900)
The back of the airbox even had enough material to support it's self on the front edge of the battery box tray.
Yes, I also use a K&N filter.
[IMG
[IMG
Sorry to hijack a bit, but I like the fairing / windshield, can I ask where you got it? Thx
  • JDRAKE4200
29 Jul 2015 20:29
#683386
Got the carbs sorted out. Previous owner only replace 2 needles and they were shorter than # 3 and 4 carbs. Thanks for all the help. More writings to come as I continue.
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jul 2015 21:17 - 29 Jul 2015 21:18
#683391
ANOTHER reason PO's suck. :angry:
Last edit: 29 Jul 2015 21:18 by SWest.
The following user(s) said Thank You: JDRAKE4200
  • JDRAKE4200
29 Jul 2015 21:20
#683392
I agree!!!!
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
  • Old Kaw Boy
  • Old Kaw Boy's Avatar
30 Jul 2015 08:14
#683438
Looks outstanding for $2400!
OLD KAW BOY
1979 LTD 1000
