Tell me what you guys think - 1976 kz900 ltd
- JDRAKE4200
Re: Tell me what you guys think - 1976 kz900 ltd
26 Jul 2015 13:07
Turbo was not for sale... Sorry. Super cool guy. Brought the bike home on Friday. Couldn't be happier.
Keep the shiny side up!!!!
1976 KZ900 LTD
2004 Sportster 1200 Custom
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
- KZJOE900
- Administrator
Super Users
26 Jul 2015 13:24 - 26 Jul 2015 13:27
Congratulations! Have you ever owned a bike with pods? If not, keep in mind that if they get soaked, the bike is going to not run good for awhile (first 1/2 hr), until they dry out. Nothing to panic about. In the pictures you posted already, it looks like if you polish the forks, cases and valve cover ends, the bike will really come alive. Paint looks real nice on it. You have a nice bike there to take to bike night. You will have a lot of interested people coming up and telling you of the one they had or their Dad or Uncle had, back-in-the-day. Enjoy!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 26 Jul 2015 13:27 by KZJOE900.
- JDRAKE4200
26 Jul 2015 13:27
I'm super happy with the buy.... Not perfect, but a good deal. It is missing a few things, but once I get a chance to go through her, I will post a list of what is wanted and needed. Thanks again guys.
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
- JDRAKE4200
26 Jul 2015 22:07
Ok..... Time for a full rundown and a list of items I am going to need your guys help with.
Just under 9000 miles- seems correct from what title has on it. Guy told me he did the following:
Electronic ignition - Dyna
Set timing
Valves adjusted
Rebuilt carbs
New Vance and Hines 4-1
New tires
New handle bar switches
New headlight
New brakes front and rear
After actually getting into her, I think he may have put a new writing harness on her. It's brand new!!!
She seems mechanically sound with no 2nd gear issues. Carb 4 is leaking out the overflow, but that is an easy fix. After sitting the weekend in my clean garage, she is bleeding from somewhere on the sprocket side between the stator and generator. Hoping that will be an easy fix.
I have come up with a long list and a short list of items I am going to need. I'm not going to restore her to original, but all the parts I take off, are going into a Rubbermaid tub just in case I choose to do so in the future. The only thing I really want to change are cosmetic items like the fuel tank, and the handle bars. Changing to a California style bar for a sportier look. And want a z1 standard tank and seat. I like the way the standard tanks look..... Super sleek.
So, here is what I need your guys help in getting. Not asking for freebies, I have a PayPal account, and will send money that way, or through the mail. Just let me know what is e easiest for you.
Need:
-Copy of the factory service manual and Ltd supplement
-Dent free z1 standard tank - paint means nothing
-Standard flat seat
-Seat and neck lock
-Stock air box, or something better than pods
-Stock grips- love the way they look and feel
-Battery stay strap
If you are able to help, or know anyone you can send me to, PLEASE LET ME KNOW.
I will post pics as I progress.
Thank you for all of your help.
Set timing
Valves adjusted
Rebuilt carbs
New tires
New headlight
Need:
-Standard flat seat
-Seat and neck lock
-Battery stay strap
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
- KZJOE900
- Administrator
Super Users
27 Jul 2015 05:09
If it is leaking when it's on the side stand, then it is most likely the grommet at where the three stator wires come out. Most people end up having to replace this grommet. Very easy to do, but does require splicing and soldering the wires. I used heat shrink tubing as well. Just do a search for this fix on the site. You'll find many tips.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- JDRAKE4200
27 Jul 2015 06:12
Thanks for a place to start. I will get her cleaned up and see what I come up with, Will do a search and if I need any help, Ill let ya guys know.
Please note I am still looking for the following:
Need:
-Standard flat seat
-Seat and neck lock
-Battery stay strap
Need:
-Standard flat seat
-Seat and neck lock
-Battery stay strap
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
27 Jul 2015 06:43
Ebay
- KZJOE900
- Administrator
Super Users
27 Jul 2015 06:55
Assuming it does turn out to be the grommet and not the gasket. Here is a couple of links. You can try sealing it like JD did or you can replace it (Z1Enterprises carries it). I would also polish the stator cover since you will have it off. Some 1000 grit sand papper, one cutting and one polishing buffing compounds, polishing wheel on a drill or a bench polishing wheel would do the trick. That is a whole other topic on best way to do it though. You see, one thing leads to another, LOL.
www.kzrider.com/forum/2-engine/584152-help#584420
www.kzrider.com/forum/4-electrical/57866...r-cover-issue#578661
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
The following user(s) said Thank You: bluej58, JDRAKE4200
- KZJOE900
- Administrator
Super Users
27 Jul 2015 06:56
Jason, I sent you some links in your mailbox that may help.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
The following user(s) said Thank You: JDRAKE4200
- JDRAKE4200
27 Jul 2015 09:57
Thanks Joe.... Gottem
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
- Kidkawie
- I bleed premix
27 Jul 2015 10:41
Nice bike! Good luck with it!
I would HIGHLY recommend installing the stock airbox as your #1 priority. After restoring my fathers Z1 with pods, the bike ran good but seemed a bit sluggish. I decided to try the stock airbox and HOLY F, did it ever wake that bike up.
Keep an eye out for stock, Kawasaki mirrors, the aftermarket mirrors vibrate like mad. There's a piece of foam in the Kaw mirrors that keep them from vibrating at speed. There's a DIY somewhere on making your own foam, I forget what site.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- JDRAKE4200
27 Jul 2015 10:43
While it's not #1 on the list provided, it is what I need the most. If anyone has one, please get a hold of me!
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
