Bike of the Month.
- Stereordinary
Re: Bike of the Month.
06 Aug 2026 07:45
That’s a beautiful Zephyr!
A breeze from the west.
The following user(s) said Thank You: moizeau
10 Sep 2026 00:43
I know I am late this month but been real busy and I had to do some digging to get the lowdown on this absolutely stunning monster from zed1015, this is one of my all time favourite bikes ever.Quick spec of motor - Dry blocked 1000A cases + gearbox. welded Z900 crank. 8-1 comp 1075 wiseco's. 1000 J head ,eight plugged/gasflowed/skimmed 1.3mm. std cams dialled in at 110 deg. blower geared for 8 to 10 psi boost for running in. plus all the usual APE/Liska/Falicon/Orient express/Camellia/PMC/Dyna and my own bits'n'bobs here and there.This show's bracing around swingarm pivot area and also rubber mounted catch tank i've just done.
Also the new swing arm spindle is of a larger dia than original so i rigged up a special cutter (that used the pivot as a guide) to machine out the frame pivot inserts, I then turned up some larger dia replacements and welded them in.
The following user(s) said Thank You: Mcdroid, ronnieV, zed1015, MFP-Joe, sf4t7
- zed1015
10 Sep 2026 03:24 - 10 Sep 2026 04:50
Thanks for that Guy.
I didn't know you were going to feature this so i'd better add a couple of pics and more info to show the recent updates since the main makeover i did earlier this year.
The Devil silencer and Suzuki GSX1400 rear shocks have just been replaced at the weekend with some proper Ohlins and a more suitable Yoshi can alongside a revised hanger to complete the look.
I'm constantly fine tuning the carburation when the weather permits and have now fitted a Powerjet to the dreadful S&S carb which adds a third circuit and fourth means of adjustment which has made a massive improvement to the fueling and rideability alongside a heavier Z1000 crank who's inertia balances out the low rpm drag from the blower and now allows a smooth idle speed.
The J head has been replaced with an earlier 1000 head and the blower pullies swapped to increase the blower speed so i now get instant boost when the throttle is opened and there is also a home brewed inverted lock up clutch i cobbled together hiding inside the clutch hub.
Once the good weather passes i've also got a nice set of GPZ1100A Unitrack cams waiting ready to drop in over winter which should perk it up a little more next year.
These projects are never really finished
Last edit: 10 Sep 2026 04:50 by zed1015.
The following user(s) said Thank You: Mcdroid, asphalt900, sf4t7, Kofla, Wookie58, kimchella
- asphalt900
The following user(s) said Thank You: zed1015
- riturbo
10 Sep 2026 05:00
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- Kofla
10 Sep 2026 20:59
Outstanding! Wow!
1978 Kawasaki KZ1000 LTD
2010 Kawasaki Ninja ZX-14
10 Sep 2026 23:46Been wanting to do this one for a while but struggled to find the time to got through the build thread.- I guessed you would be OK with itThanks for that Guy.
- MFP-Joe
- kimchella
11 Sep 2026 15:40
What a fantastic bike, awesome job.
Rich.
Rich.
KZ650B1 frame number 225
New Zealand
New Zealand
- ronnieV
15 Sep 2026 08:20
Absolutely stunning build. Something i could only dream to do. Someone already said it,but WOW!!
- Buzz Nichols
15 Sep 2026 10:47
Wow. Just an absolutely glorious machine.
1978 KZ1000 LTD
1978 KZ1000 LTD
