stalls when its leans to the right or when pit in
  • bb41077
  • bb41077's Avatar Topic Author
23 May 2015 18:10
#673381
So I got this 85 zn700 ltd, put in starter clutch and finally messed with the carbs some got it finally running on all 4 carbs, finally, but now when I start it and sit on it and lean it to the right some the green neutral light flickers and it stalls out. Every time now. I put it into gear, stalls,???? Any ideas out there.......
Bruce Bakken
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: stalls when its leans to the right or when pit in
23 May 2015 18:28
#673386
some models have a starter interlock which means you can only start with:
side stand up
in neutral
clutch in
often these get disconnected.
  • bb41077
23 May 2015 18:48
#673391
Right, I think its something weird cuz I have to start it in neutral with the green neutral light on the box on, but when I lean it to the right, the whole bike, the light will flicker and go off, and if the bikes running it will shut off, now when that happens I either after to turn the steering wheel to the left hard the light will come back on and it will start... Its gotta be a wire right. Idk
Bruce Bakken
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2015 19:12
#673397
Check your multi connector plugs. Sometimes the pins will pull out just enough to do this.
The following user(s) said Thank You: bb41077
  • spdygon
  • spdygon's Avatar
23 May 2015 20:28 - 23 May 2015 20:28
#673405
What Swest said....this just happen to me...connection under tank. One pin was loose.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 23 May 2015 20:28 by spdygon.
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
Re: stalls whetn its leans to the right or when pit in
24 May 2015 07:51
#673469
Sounds like neutral safety or clutch sSafety switch issues....
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
  • Tyrell Corp
24 May 2015 07:56
#673470
The neutral switch is under the left casing, and gets pretty mucky there. If you clean it up, and gently squash the female connector just a touch it will probably fix it. Had this one mine recently.
  • davido
  • davido's Avatar
24 May 2015 10:05
#673493
I had this on my CBX750. A lot of times when I went round a corner,the bike would splutter and fart. Turned out that the fusebox (which is on the top yoke,twixt the handelbars) had water in it. When it was level,no problem the water level was too low.When I tilted the bike (into a turn) the water level would rise at one end and mess with the fuses! Cleaned it out and everything was tiddley pooh.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • bb41077
25 May 2015 13:41
#673670
Keep messing around with this connections I cleaned um and the neutral one seems tight to the connection tit but after a quick ride back to the stalling when I put it into gear????? Ugh
Bruce Bakken
  • MDZ1rider
  • MDZ1rider's Avatar
26 May 2015 09:34
#673838
Sounds more like a side stand safety switch now. The neutral safety switch will stop the bike from starting unless in neutral. The side stand switch will stop the bike from moving if the side stand is not up. Your bike starts, but dies when you put it in gear to move.
  • bb41077
26 May 2015 11:52
#673854
It'll start if the neutral light is on, otherwise I can jump it off the thing and it'll start but can't put it into gear cuz it'll stall, or as I sit on it and lean some to the right it'll shut off, right off. Idk
Bruce Bakken
  • bb41077
26 May 2015 12:06
#673859
After I ride it. When I ride around for a min and come home and go to leave or start it again is when its all f'ed up
Bruce Bakken
