- Thank you received: 1616
Air Tech clip-ons?
- loudhvx
Obviously, you can always use a different master to get around that problem. But I have come to like the welded ones, plus they are not very expensive.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Serpent7
- Nothing professionally, only for fun...
loudhvx wrote: Some KZ's, like my 550, can't use clipons that clamp onto the bar. The clamping mechanism interferes with the front master cylinder assembly. The master cylinder is a long rectangular reservoir that hugs the bar over several inches. That leaves no clearance for the clamping mechanism to hold the bar. They have to use a bar that's welded onto the fork clamp.
Never thought about welded ones.... Hmmmm
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
- loudhvx
The kind using aluminum clamps usually have aluminum bars, but I'd have to get a different front master to use them.
1981 KZ550 D1 gpz.
Other links.
- DoctoRot
- Thank you received: 675
- DoctoRot
I just saw you have a 79 1000 shaft. those are 40mm forks i believe. NOT 36mm.
- Serpent7
DoctoRot wrote: OOOPS
I'm starting to learn that shafts are completely different animals...
19 Audi Q5
73 Volkswagen Thing
- loudhvx
Yes, but sometimes that's good. My buddy is converting one to chain. He says the shaft frame is the desired frame for a swingarm conversion because the frame is wider allowing for more chain clearance etc.Serpent7 wrote:
Personally, I think the ST is one of the best looking KZ's.
1981 KZ550 D1 gpz.
Other links.
- Serpent7
Yeah, the ST seems to be put together a little better, and with more quality than the regulars. Thicker forks, nicer frame, I believe wider rims, Shaftie all the way for me!
I got some conflicting sizes though now for my forks. I've seen 36mm, 40mm, and 41mm. I'm now very unsure as to what size clip-ones to order... Any ideas?
19 Audi Q5
73 Volkswagen Thing
- Dumont
- Thank you received: 2
Scott
78 KZ650(Project)
09 Monster 1100s
07 Monster S2R1000 sold
97 Daytona T595 sold
95 KX250 sold
82 GPz 550 sold
87 Ninja ZX10r sold
79 KZ650csr sold
82 CR250 sold
- DoctoRot
www.z1enterprises.com/ItemDetails.aspx?i...2f9.5&item=KS16-1036
- Serpent7
DoctoRot wrote: theyre 40mm. if you looks up fork seals for your ST (KZ1000E1) on Z1 enterprises you'll see it says for 40mm forks.
Thanks Doc!!!
19 Audi Q5
73 Volkswagen Thing
