broke down....
- mik3mac
1976 kz900 custom
- asevans
- 4TheKZ1000
- Visitor
asevans wrote: Fuse?
+1
Also why is it blowing a fuse? if it did.
- JR
- Thank you received: 445
1. Either one of the cables to the battery or ground have come loose
2 the main fuse has blown.
3 Ignition switch knackered.
This happened to me at the weekend and it was the main fuse. After replacing the fuse it fired up and I rode home. I spent 4 or 5 hours on Monday looking for a short and found nothing. Rode 40 km today and no problem.
A few years back I blew a main fuse and blew the replacement immediately and ended up pushing the beast almost a mile home. Eventually I found a short in the headlight bucket where some old electrical tape had come off a connection - blame PO. After a proper repair all was fine.
- Thank you received: 2829
- RonKZ650
- Thank you received: 240
- toolmaker
- Thank you received: 19
I live near Portland, Oregon and my rider is a '76 KZ900 I bought new. I'm also in the process of restoring another one and a '73 Z1.
- koolaid_kid
- Thank you received: 99
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- mik3mac
1976 kz900 custom
- bluezbike
- Thank you received: 104
79 KZ 1000 LTD
- roy-b-boy-b
- Thank you received: 103
If you were to carry a small length of wire with two alligator clips you van run a wire from your battery to the hot wire going into the coils. This has come in handy a couple of times.
- JR
roy-b-boy-b wrote: Everyone rags a Wiredgeorge ignition relay but I install them on my bikes because it is a simple way to hotwire the bike.
Thanks Roy. That sounds like a good tip. Am I right in thinking that I could also bridge the terminals on the starter relay with a screwdriver blade to turn the starter motor over ? I'm to old to bump start. This would be a last resort / get you home kind of roadside repair.
